dryclean1
hello fellow washer nuts. its me the drycleaner. I have a 1946 bendix model s or diving bell as they are called. I was reading on an old post about the semi-auto bendix model s. there was some discussing about a way to run the drain line into the top of the washer to re-use water if you wanted to. I have tried this with mine using a fernico adapter and I get a lot of spay over with it. did they make a special adapter for the drain hose that fit in the top where the detergent goes? any suggestions would be great. thanks the drycleaner
