Great job!
Robert, looks like you did an awesome job. Our new house has all copper, with 1 1/4" main line coming in from the well and 1" main trunk line in the rest of the basement, branching off to 3/4" supplies.
Question - did you think about putting in a recirc loop on the hot? Our bulider did that standard, and wow, what a difference. You have hot on tap at every point and don't waste any water waiting for it to get warm. Works great for the DW and washing machines too. There are two types of these systems, powered, where there is a little pump that is typically set on a timer, and passive.
Our bulider reccomended the passive system. Just Right by Nibco. See link. This valve uses natural convection to keep the water recirculating. Additionally, when you first turn on the tap, the Just Right valve uses water from the recirc side of the loop to fill the water heater, so it is actively sucking the return, pulling the hot even more. The link explains better than I can.
The next house our builder built was right when the price of copper sky-rocketed. Interestingly he changed over to PEX home run system. Each and every tap has a home run to the manifold each with its own shut off valve. This sytem might have acutally worked better in our house since none of our first floor walls line up with our second floor walls. What results with copper is many, many 90 degree elbows, each and every one slowing the flow and reducing pressure. The pex system totally eliminates that.
Anway, great job. Did you have to re-sweat any connections that leaked? I hate that.
Andy
http://www.nibco.com/assets/Justrt.pdf
