wholelottared
hello everyone!! i've been using my Bosch Home Professional WTX87EH0TR tumble dryer for almost a year now, and I kept noticing new thing that I didn't notice before.
it always acts differently about this, and it's not something that it constantly does, which makes me wonder what's the logic and explanation behind it.
it's about the fan that's at the bottom right of the device.
don't know if it makes a difference but i always use this program: cottons with "low heat" setting.
here's a list of the different behaviors it does:
1. fan never turns on during the program.
2. fan turns on only right before the end of the program, on the last 11 minutes when AutoClean section starts.
3. fan turns on sometime during the program, and lasts throughout the whole program. it doesn't run continuosly though, but more like fan works for 2 minutes, stops for 2 minutes, then repeats.
4. fan runs through the ENTIRE program, never stops, and continues even AFTER the program is finished. like the program is complete, everything ended but the fan is still running. it stops after you open the door or turn off the machine. this is my favorite one, because it dries at a really low temperature this way, and the laundry comes out not even warm but still fully dry. wish i was able to choose this behavior manually somehow.
5. during the program fan is constantly running without stopping, but the condenser/compressor keeps turning off and on repeatedly. this one is the most weirdest one, because it only happened once, but i wasn't even sure if it was a glitch or not. i thought it was weird glitch, so i cancelled the program, took off the plug, waited a little bit, restarted the program, but then it did the SAME thing. so maybe it wasn't a glitch and maybe it was sensing something weird with the electricity or something. the compressor was running for like 15 minutes then the compressor was stopping even though drum continued to spin, and then compressor was starting again after some time, then repeating. as a result, the drying time was extremely long (like 2.5-3 hours, which normally would've ended in like 1 hour). everything was dry at the end, but it was the weirdest behavior ever that i couldn't understand why. it never did it again. the fan was working even after the program ended on this one too.
so, what could be the logic behind these behaviors? another thing i noticed is that the fan is pumping air inside the device, it's not pumping air outside. i realized this by putting a towel to the grid at the bottom, and it was holding the towel still, instead of blowing it away lol. is this the expected design or is the fan spinning on the wrong way or something?
sorry the post was a bit long, but i know that there are many professionals on this site so i would be soooo happy if someone can explain these all to me, and the logic behind them. my guess is that they are either glithces, or they are something that machine decides according to the electricity or the humidity of the room or something? i don't know, want to learn the details.
thank you so much!!
thank you so much!!
