Does anyone know what all the extra hoses comming from the trap, going to the pump, and one is "T"ed off actually do.......
aside from the 2 big hoses, in/out for drain......and then 2 smaller ones in/out for the filter......and then a "T" off the filter input, and one going into the top of the pump....puzzled....
I got a new belt from PepBoys, they matched one up....aside from those clamps as mentioned, was easier to replace than I thought......for the motor, only remove the front bolts, the rear ones just need loosened, and the motor plate slides forward and off, or will tilt enough to get the belt out and replace....
Brake cleaner, from PepBoys also, works great on the rollers, just line the underneath with paper towels, the spray removes any oils or grease from the rollers while turning by hand, and dries in an instant....will also clean that base pan to a sparkle....
Nice machines guys.......
I got one from Darren, fixing a small leak, and should be up and running soon......this is my first one, ever, absolutely amazing machine to watch in motion....fascinating.......videos just don't do it justice!
one thing I am changing on mine is the small drain hose that comes with these......the hose comming up from the pump is a little larger than an inch, so I a trying a new port and larger drain hose to see if it will pump out faster....but still a powerful pump with the small hose and slow speed...
