NOT how I like my dryers!!! Remember a while back when I asked how my 1968 GE Versatronic dryer would have shorted out like it did. By "shorting" I mean it surged so badly it flipped the main breaker for the entire house!
I finally had some time today and started diving into the old thing. It needed a good cleaning anyways. Got everything apart and grabbed a good vacuum (an early 60's Singer canister to be exact) and started going at it.
The heating elements both looked good so no problem there. Motor is spotless and hums nice and quiet. The wiring harness all looked fine as well. I couldn't really peg what could have happened. Then I started thinking about when it shorted. I opened and could smell burning wires and could have sworn I saw some smoke coming up from the lint trap right under the door.
I took the front off, took off the door, took the air duct out and really cleaned in there too. Turns out where the sensor is located right inside the door there is a small little thermostat located just under the lint trap. I got the little booger uncovered to find a nicely charred thermostat and some badly burned wires. In fact one of the wires was completely burned through and broken.
Anywho, at least now I know what happened and it should be an easy fix with a new thermostat and a couple of new wires. Probably not more than $20 total.
I took a couple of snapshots for you guys. I also headed down to a local old appliance store to inquire about a new part. They said the older dryers tend to do this and it's not uncommon in Maytags too.
