gusherb
My dad picked this up somewhere on Craigslist for his basement and I'm curious if someone might be able to tell the age of it. I found a vintage ad for the Deluxe 15 from 1978 so I know it's from the 70s.
The fan motor bearings appear to be going as it's a bit shaky and the shaft has a bit of play in it, but other then that it runs great after giving the condenser coil a good cleaning. The compressor is made by Danfoss and it runs QUIET. The fan not as much. I have a 1983 White-Westinghouse pretty much identical but with a different front cover and in the faux woodgrain that was so popular during that time. The compressor on that isn't nearly as quiet (albeit also being a Danfoss) and the fan is a bit noisier. It also uses R500 instead of R12 like this one does.
[this post was last edited: 8/19/2015-21:13]
