Westinghouse dryer seal help
I'm following this one too... I need a door seal for my 58 D-100 Westy dryer badly.  I just haven't quite figured out what to use to replace it, as the original part seems to be well and truly NLA.
Does
The self sealing weather stripping work? I do use a foam weather stripping for sealing the door And now I need to try and hope that it is physically tall enough to make a proper seal with the door, And if I need to use weather stripping for in between the drum and that bits section there
Does
