Westinghouse LTJ (?) Heavy Duty Washer
keymatic
Apr 12, 2002
664
London / UK
Afternoon All,
I finally took delivery this morning of this gorgeous washer from Italy, it is New old stock Westinghouse from the 70’s, never used.
The boot/gasket has totally perished, anyone got any suggedtions ? Another guy on here kindly said that. Kenmore or Frigidaire front loader boots from the 90’s can be adapted ? I would love to get the machine going. I am also looking for a “Heavy duty” badge was has got lost in transit.
Any help would be really appreciated :)
Cheers
Keith
Totally Cool 3 Belt Westinghouse
WOW Kieth a brand new WH Washer, that design would be a late 60s machine in the US but who knows when this one was built, it will be interesting to find out when you get into it.
I would have a good used boot for this washer that we could send.
Darren is going to be over here in mid September I could maybe send it home with him.
John L.
Thats a very great find and a beautiful Westinghouse FL. I bought one very similar to this one used in 1980 for I believe $150.00. Unfortunately it didn’t work as well as I’d hoped for and the dealer that I bought it from had told me that I had 30 days to exchange it and apply the purchase price to another machine.
I traded it for a new Maytag Fabricmatic, which was a good machine, but I was disappointed that the Westinghouse didn’t work out. I’d really wanted an FL and the new ones were just too expensive for me at the time.
I hope you get many years of good service from this great find!
Eddie
That's a great score and looks to be in wonderful shape but for the boot. My family had the LTF590 like Tom's family did. Looked exactly like this machine but as Tom mentioned had four water temperature combinations instead of three. Does this one have a tub light? The LTF590 did; and it had two cycles - regular and permanent press (which was just a short cycle.) I think we got ours in 1965.
Morning John,
Thank you for hunting out the boot, i sent you mail.
It will be great to get this machine going.
I just need to get a transformer now as the machine is 110v and as you know we work on 240v this side of the pond :)
Thank you so so much for your help
Cheers Keith
Westinghouse had a large trade with multi-family housing and their stacking laundry sets. The stack washer and dryer fit in a lot of places and once they were installed, the washers were replaced as they wore out. Philco abandoned their front loading washer in the 60s, although they never had a stack pair, and ceased production of their combo by 1969 so these were the only domestic tumbler washers here. In short, they sold many of these laundry machines.
Morning All,
Thank you for all your comments on my recent find, really looking forward to getting it up and running once i get the door boot replaced.
Just need to find a "heavy Duty" badge and it will be perfect...
Many thanks
Keith
Transformer
I suggest you look into those yellow square ones the construction workers use as it would be man enough to cope with any surge required to turn the drum. Sorry Keith I forget the actual name of them :)
What would you do...
Morning All,
I recently posted that I had shipped from Italy to the UK a brand new Westinghouse LTF600 washer dating from the mid-60's, whilst the boot gasket needs replacing which I have managed to source a replacement I am wondering if I need to do anything before switching the machine on for the first time ? would a any parts needs greasing / oiling ? filling with warm water and soaking to allow parts to re-hydrate ? any recommendations would be greatly appreciated.
Regards
Keith
Checking Over a New Mid 60S Westinghouse Washer
Hi Keith, I would remove the pack panel and check that everything moves freely and maybe put a few drops of light machine oil on the idler idler pulley bearing, rear pump idler bearing and the rear helix spring behind the large black center pulley. You just remove the 1/2"bolt in the center and it lifts off easily [ this spring was greased at the factory but a few drops of light oil will rejuvenate the grease ]and reassemble.
I would also poor about a gallon of very hot tap water in the tub and let it sit for at least 30 minutes.
We can't wait to hear how it goes.
John L.
Morning John.L,
Well i have finially got round to replacing the boot on the Westinghouse LTF-600.
The manual says no wrinkles ? Whilst the boot lip looks a little wavy i did everything according to what the manual says..does this look ok ??
The door needs a bit of pressure now to close it, i guess until the boot settles down.
Now for a test hopefully next weekend.
Many thanks again.
Cheers
Keith
Three belt Westinghouse front load washer
Yay Keith, glad you’re getting this project going. Will be exciting to see what you think of this machine.
It’s a little crude, but a good performer it was the only frontload washer. We really had here in the states for a long time we used to have some diehard customers it would always have a front loader and like these machines a lot.
I have seen machines were the door boot is sort of puckered and wrinkled a bit like that. Not sure what causes that in theory it was not supposed to be like that but I don’t think it’ll hurt anything. Maybe some good hot washes will make it calm down a little bit ,
Anxiously awaiting to see how it works.
John.
