pierreandreply4
what are the chances that my Maytag mvw6230hw fails after 5 years here are the problems it has 1 do not dispense hot water if warm or hot water wash option in wash rinse temp option is selected (*recuring problem happen before then resolve itself then return) 2 if i select the bulky item cycle, bedsheets to wash with extra rinse i notice when second rinse or extra rinse is off when rinse. Start its suppose to start the fill from the main detergent dispenser then switch to fabric softener dispenser, but at start of rinse huge buzzing sound then fabric softener kicks in for the fill. 3 if deep water wash option is selected at first spin pump start for the drain stop a second then start, again could all these problem be link to a faulty control board on the washer. I went in the diagnostic test mode tested hot water valve its starts but its when i use the option for warm or hot nothing, i am no expert so have no clue what to think and i also went to thank panasonicvac for alerting of the washer failing after 5 years
