vintagekitchen
- Joined
- Aug 28, 2011
- Messages
- 706
All over the internet it seems like people equate ironing sheets with forced labor in a Siberian work camp, or consider it an activity only practiced by the ever so slightly insane. I just don't understand the big deal. I still iron all my sheets exactly the way my grandmother did, with a GE dry iron identical to the one she used, and nothing in life could be easier.
All one has to do is remove the sheets from the clothesline or dryer while still barely damp. This eliminates the need to sprinkle them. My grandmother did this with all items to be ironed. If you arent going to iron the same day you wash, place the sheets in a plastic bag and leave them in the bottom of the refrigerator overnight. (After gramma got an automatic washer and dryer she did all her laundry and ironing the same day, ironing each load as it was removed barely damp from the dryer.)
Begin by folding the fitted sheet bottom to top, tucking opposite corners inside each other, this makes the sheet into a manageable size. Use the large end of the ironing board, and first stretch the corner of the sheet over the corner of the board, with the excess piled at your feet, so the hot ironed fabric moves away from you as you iron, keeping you cooler. Iron the corner, then keep ironing, moving the sheet across the board. At the end, flip the sheet and iron the other side. (this is necessary since the sheets are folded in half.) Now fold up the fitted sheet, and set it aside.
Next iron the pillowcases, fold them, and place them on top of the folded fitted sheet.
Last fold the flat sheet bottom to top, and iron it the same as the fitted sheet, on the large end of the ironing board, moving the material away from you across the board as you go. Flip and iron the opposite side, then fold the flat sheet. When you get to the last 3 folds, place the stack consisting of the fitted sheet and pillowcases on top of the flat sheet, and finish folding the flat sheet around the stack.
You are left with the smoothest crispest sheets ever, each set folded into a neat little package that takes less space in your linen closet, and eliminates the need to search through the closet for all the pieces of a set when you make the bed. All told, it takes me about 15 minutes to iron a full/double sized sheet set this way, and I do it while watching tv. I dont see why people think this is such a difficult time consuming act.
As a last note, don't bother ironing the sheets if you are going to use steam. Dry ironing barely damp sheets leaves you with a wonderful crisp finish, but steam ironing dry sheets makes them limp.
