What Kind Of Water Do You People Have Out There?
Yeah Dave,
I think next fridge will be a Whirlpool. Generic filters don't fit most fridges.
In fact, a GE water cooler doesn't even use the same one as their fridges.
They've had tow styles, one shorter and wider, one thinner and taller.
Alas GE is no longer even on the Dow Jones industrial trading list.
Been there before myself, bought the book, and almost the farm.
Then my spouse would be singing that old Bobby Godsboro song "Honey" I miss you, and I'm bein' good.
So no, I couldn't buy the farm before my time comes. I don't know if I was even depressed. When Kroger, Meijer, Walmart,etc. didn't hire me I was bummed, but I hit the bricks and got a job as soon as I could. Not much of one, but I gave it a couple of years. Still wasn't much of one, and was making me sick. I was on auto pilot.
Then my folks got older, sick, and needed some help. I miss them dearly.
Otherwise, life is pretty good. Just waiting a few more years to collect my retirement. I'll draw a bit less, so my spouse can have at least half, if I pass on first. I think I likely will. My family has more health problems more serious than arthritis, and bad backs.
Fridge
I have the exact same refrigerator. I actually ordered a Whirlpool direct replacement and they sent the wrong size. It didn't appear any different until I tried to put the filter in. Now, it is stuck in the fridge until I need a replacement. This has happened twice. Im not sure why it is so hard to send the correct one!
 Wausau’s water is moderately soft.  Typical testing results: 80 to 100 mg/l or 4-1/2 to 6 grains/gallon.
Wausau’s drinking water comes from six municipal wells, all of which are located near the Wisconsin River. These wells range in depth of 95 feet to 160 feet and pump anywhere from 900 to 3000 gallons per minute.
Cape May around 20 years ago had a major water crisis on the July 4 holiday. We were rapidly running out of high quality water. Cape May is surrounded by salt water and that salt water intruded into four of our five wells. A commission was formed by the city. I was a member of that commission. We looked at the problem and over 16 possible solutions to the water supply issues.
The end result is Cape May has the first desal plant in the North East. The capacity of the plant is around 2 million gallons a day. This meets our current summer (tourist season) demands. The feed for the plant is not sea water, it is brackish water from an aquifer know as the Atlantic City Sands. This reduces energy cost and gives a higher yield than sea water.
The water from the desal (reverse osmosis) is excellent. The link is to an article about the plant and the quality of Cape May water. It is interesting to watch our visitors (AKA tourist) loading up with bottled water when better quality water comes right out of the tap.
Harry
http://www.ocsentinel.com/oc_suregu...cle_01852164-020c-11e4-a61d-001a4bcf6878.html
I've extremely soft water. The only slight issue is it contains a trace of iron from ferrous rock in the area.
It can leave a very slight trace of It on the kettle but it is very, very minor stuff. I only need to descale the kettle and the coffee machine maybe once a year.
The washing machine and dishwasher never have had any issue with anything..
So earlier,
I was casting a few lines at the park in the local river. No nibbles, so I went walking. I pass a bridge where kids paint grafiti.A boy and girl left their names above this little ditty; "river poopers forever".
Oh, it will be gone soon, the city is adimate about a family friendly park.
Another hundred yards ahead what do I observe? Teens swimming. Yuck! I figure if the bicycle police man who passed me a minute sooner didn't make them get out, it's not my place to tell them to either.
Whats in your water?
Fade of hard water!
I live in Cleveland Ohio area and in here you will find about 10 grains per gallon hardness in the water. MY family uses 500 gallons of water per day.
So, I need a system capable of providing a minimum 5,000 grains removal capacity per day. Just a rule of thumb, the typical 8" diameter home water softener will usually provided 1 cubic foot of softening resin, which gives you 30,000 grains removal capacity when regenerated with 15 lb. of salt per cubic ft.
This means that the typical home, single tank system would need you to regenerate it once every 6 days.
There are some systems, known as duplex, or twin alternating, which get away with using smaller tanks that just regenerate more often and flip back and forth automatically as you use water.
The most efficient, green and reliable system on the market is manufactured by Kinetico, in Newbury Ohio. The patented control is the only self-regenerating, non-electric controller on the market. It is an engineering wonder.
I hope this helps.
Oh yea, as far as size of your softener, always remember this, you will lose some pressure across the softener, so always purchase a softener that has slightly larger connections than your household plumbing. As an example, if your home plumbing is 3/4 inch, purchase a 1# softening valve.
https://homescute.com/how-to-size-a-water-softener/
LADWP manages to deliver tyhe super modern powdered water!
It's basically vitamin water, full of vitamins and minerals, but in a modern dehydration technique (same as used for astronaut food) where all the water is removed and only the vitamins and minerals are left. You just need to mix that powedered water with some water to have water.
Jokes apart, sometimes our water is so hard that I seriously think it's milk instead of water. I can literally fill the kitchen sink and not see the disposer plug.
I got so tired of soaking my shower head in vinegar because it sprays everywhere like a lawn sprinkler that now I keep a spray bottle with vinegar in the shower and spray it after every single shower. (2-3 times per day in the winter)
My bathtub spout had an interesting stalactite, but a few days ago i hit it with my foot and it broke (I kept it as a souvenir).
The bathroom sink has a very nice stalagmite growing next to the drain.
From our city's water treatment plant manager January 23
the Finished water leaving the water treatment plant has a harness between 200-215 mg/L.
OuchC that’s some harshly hard water!! Without calling and asking the most recent information I have is from a 2014 report, 3.3 gpg hard. Seems a little on the light side compared to what the water leaves on things, but I still feel we need a softener.
*UPDATE* Just found a more recent sampling that puts my part of town right in the 10-14gpg (173-242mg/L) range, which is where I'd have guessed based on the deposits we get on things.[this post was last edited: 2/6/2020-12:10]
Moderately hard water. All of the faucets have encrusted minerals on the end of them. It doesn't help that the water travels through pipes over 100 years old. The few times I have seen the insides of them for minor repairs, they are more than 70% filled with minerals and rust. Call me crazy, but I have drank Indianapolis tap water for so many years that bottled water tastes wrong and I am not a fan.
I just checked ours with Irish Water's website and it comes up as having conductivity of 178 µS/cm which rates as pretty soft.
Ours is rather
wet, and some even green, as of late, when an abandoned electroplating shop leeched Hexavalent chromium six onto the freeway below it. It was left in vats and ate through the ground, infiltrating a storm drain. The owner of the formershop is in jail serving a one year sentence for polluting, not just there, but on his property up north in Sanilac county where he diposed of drums of chemicals on his site. He was said to have immersed his arm into the liquid poison inf ront of the judge to prove it safe. Nice eh? If you've heard of Errin Brochovich, you know HXC6 is not safe. PGE&E lost a class action law suit won by Brochovich, her boss, and team. Also brown sludge washing up onto peoples lake front lots on Lake St. Clair this month.
Integrity is nill these days. Do we still have an EPA? Talk about preventing permanent damage by congress? A wake up call for them is on the way as young poeple will be voting for the first time soon.
Would a whole house RO system take all that crap out of the water?
And I agree, this is the kind of thing the EPA was meant to deal with, and yet it seems they're always the last to do anything when it happens!
