What's with Home Depot's HVAC system in the stores?
superocd
Jul 14, 2016
200
PNW
I'm an HVACR guy by trade but I am stumped as to why every time I walk in to Home Depot and walk around, I am invariably blasted by a jet of air coming from a large ceiling diffuser in its own "box" or plenum (no ducting that I can see). I'm almost positive that there is a high-velocity centrifugal (or axial) fan in each of these.
But why?
If these are just straight fans, wouldn't it have been wiser just to utilize the economizer that is installed on 99% of packaged rooftop units? They already have the ductwork for HVAC in the store. It just seems redundant to have giant, independent fans blow a blast of air into the space.
There would be no way that these are centralized. In fact I heard the motor spool up--as clear as can be--as I was standing right under one. You never really hear the blower motor on a centralized system, whether the system is heating, air conditioning or ventilation.
Good point about it being an evaporative cooler. I'm near the coast, though...I'm wondering why they'd implement one with our humidity levels? A straight intake fan setup (or just running the economizer) would suffice. Introducing moisture into the conditioned space might cause some problems around here.
I knew that it wasn't an AC system because I've never seen an axial on the evaporator side, let alone for anything else that requires moving large amounts of air over a long distance. A veteran in the field did see a forced air furnace with an odd-looking axial fan (?!?!?!) attached over the heat exchanger, it was ancient though and Was probably the last running example in the US.
The units here where I live are normal gas heat and electric a/c's. There are numerous one located all over the roof. You can see them as you drive into the yard. Road slopes down to the store so you can see the roof. No chillers here maybe because of the extreme cold weather we get.
Jon
if anything, I would ask a commercial HVAC installer for info as to why certain systems are used for some applications...
but you can have that a hundred times asked, why one installer would install or use a system one way, only for another installer criticize as in, 'what the hell were they thinking?'....
many times we see them install, but not THINK!
Our local Homeless Despot
Loses several staff every summer at the start of the 'cooling' season. Which is, apparently, dictated by the tomfool idiots Down South, not by our actual conditions.
The swamp coolers stink - they never get cleaned.
They make the store cold and clammy - and we have under 50F days in JUNE at our altitude.
They drip and drizzle.
Sigh.
I've felt the comfort of mobile homes cooled by the two-stage systems in Arizona, so I know they can be done right. These, however, are a disaster.
Homo Depot around here just uses regular RTU's (usually see Aaon). Not much for ductwork, usually just a plenum dropping down from the RTU into a 4 way diffuser aimed towards the floor. And they use ceiling fans for extra circulation.
At the front of the store they have an RTU for the registers/customer service with a diffuser over each station. For the entrance they have some pretty large unit heaters.
Out west I've seen swamp coolers, seems to work ok in the dry areas. I forget how they were heating those places though, probably duct furnaces I feel like. In Arizona they were using regular RTU's.
Lowes pisses me off, they keep it around 76° in the summer which is real stuffy especially while moving around. All the stores used to keep it between 72-74 until around 2009. Now it's hard to go anywhere that's cool enough.
Martin,
The installer would not have a say in the decision as he would certainly be adhering to the mechanical drawings for the building being constructed.There are plenty of mechanical engineering firms submitting their ideas to the idiot upper management of each firm.Pennies sometimes dictate which plan is chosen.Our units in SC stores are truly air conditioned while some have swamp coolers in the semi enclosed garden/plant section.
I have installed the HVAC in many Burger King's in my area which required conditioned air be used for make up air for the broilers and fryers--STUPID-When I objected to B.K. corporate in Florida,I was told to build it their way or no way--Period.
I avoid Lowe's like the plague
Their corporate position on transgender people is disgusting.
But, even if they were pro-American, their staff is C-L-U-E-L-E-S-S.
I want people I deal with to know MORE than me, not less than a stale cucumber which got thrown behind the dumpster a year ago at the organic grocery store down the street.
Ours will put seedlings out IN THE SNOW because corporate says to - and we get snow at our altitude 12 months out of the year some years. Well, the ones which end in even or odd numbers, mainly.
Lowes
I simply don't care for them because they're always priced higher then Home Depot and Menards. Let alone some of their policies and non existent customer service. HD isn't much better though, and they've been replacing everything in the store with garbage quality store brand shit that's been pissing me off. After that I started going to Menards more for certain things and it appears they might be doing the same with more stuff...
In the end I don't care much for any of those stores and wind up ordering online when I absolutely refuse to settle for junk.
duke
not saying all, but there are ones that do what they are supposed to, and ones that try to get away with, or OVER on someone if they can.....using the cheapest basic system...
there are ones that if they can get away with charging higher amounts, and delivering a substandard system, they will......
if the guy who built my house knew anything when it came to putting in the heating and water tank in, I wouldn't had to redo it with the proper equipment....he just went along with what they told him without gathering his own information first...
believe me, if I could get the original installer to come back and install what was supposed to be put in, in the first place, and at his expense, I would have....
plus, the new system is a bit overkill, my choice, but works like a charm....and like its supposed to....
believe it or not, the creature comforts of a business like Home Depot/Lowes, or any business for that matter, is for the customer, not the employees....granted yes, your working and building up a sweat, BUT its the customer walking in from the hot humid outside temp, into a slightly cooled area is to prevent the SHOCK of temp changes from one extreme to the next, especially for seniors, that sort of shock could cause a medical condition for them....
Martin,
I agree that there are shady installers.I was merely pointing out that the owner/builder of the structure usually picks which mechanical systems are actually installed.Usually the cheapest wins out.
Shady incompetent contractors are another issue and man could I tell some stories.
Glad you finally have gotten yours working properly.
Are you talking about an air curtain at the doors or general ventilation? I keep seeing articles and ads pushing the various destratification systems, either fans or... Maybe that's what's being done?
I miss the huge round HVAC diffusers that stores used to have back in the 1950s, 60s, 70s, 80s.
I noticed around the late 1980s the warehouse-style stores started going to these roof top units where each having a single vent. That's mostly what you see in today's ceiling-less big box stores. And even store with ceilings started around then, such as my Kmart has this system from the early 90s. I'm not sure what older Home Depot stores used, maybe they used them even earlier.
Although most new supermarkets I see still use the ducted systems, and a few even use the round diffusers. I think Walmart still uses ducted systems too in their new stores but not sure.
What you're seeing is the exhaust fan to use to clear the building from smoke or any other harmful product in the air..
We have them in our store, and I was told by a co worker who was there for the "smoke" test, and he said the building was cleared in 5 minutes when these fans kicked in.
Also, We have the roof top units, and avg 20 ton per unit. Our store has 12 of them, and they all have the economizer on it.
Our Kmart has the massive round diffusers probably original to the store, but they must've replaced the central chilled water cooling plant later on as they have very large RTU's on the roof now, but those diffusers remain in place.
The Menards down the street that is also in an older space has those large diffusers too and they still have the original central cooling plant in place. The wal mart by my house has the square lay in diffusers in the drop ceiling which are from the early 90s or so.
Oh and pretty much every Target store uses those giant square diffusers which I've always thought were interesting. They used to be flush with the ceiling then in more recent remodels they replaced them with ones that protrude down a few inches - possibly to reduce dust streaks on the ceiling tiles(??)
Square vents at Walmart
That's what our Walmart (also from the early 90s) has as well, with one big square or maybe two. The grocery section was built on in the late 1990s and has the exposed ductwork with vents on the sides.
I don't think I've ever seen a Walmart with round vents, the oldest ones I've been to were early 80s and had same white square vents that had maybe three squares.
Our old Publix, before it was remodeled had the huge round diffusers and they were silver aluminum and had I think one big circle in the middle.
Our Winn Dixie still has white round vents from the 80s with maybe three circles even though it was remodeled in 2008.
The old Scotty's hardware from the 80s had the round vents also.
