Wheel for KUDS220T4
gadgetgary
Jan 31, 2005
3,867
Bristol,CT
Which specific wheel are you looking for?
From your comment above, it sounds like the wheel for the upper rack has broken. This is a common occurrence as the machine ages, as the wheel gets brittle and falls apart. If that's what you are looking for, the pictures you posted are not the right ones.
On these machines, you will have to pull it out and unscrew the wheel from the inside. There is a nylock nut on the outside that holds the screw secure.
If it is a different wheel, please let us know.
