maytaga806
Hi everyone. All this time I thought my whirlpool portable from 2006 had a sound tuned absorber which came out in 1998 I believe, only to realize mine doesn’t have one just recently while I was checking on things underneath. The 2003 model I got for parts had one though, and to me, it didn’t seem to really do much as it still vibrated during the drain cycle just before the pump would cavitate. Were the absorbers just non effective which is why whirlpool decided to stop installing them in the machines somewhere in the 2000s? I watched several repair videos of other newer powercleans after this finding that mine didn’t have one, and in the videos they all had absent absorbers.
I had to clean so much dust out of the underside of the motor. Since this is a portable it’s gotten quite dirty under there and I managed to clean all of it out but whirlpool was not very intelligent when making these portables in the way they didn’t even install a shield under the unit to prevent this from happening, it should be completely covered on the underside instead of being totally exposed and it would certainly help with noise reduction too. I just added some extra insulation to the lower panel while I was at it and it helped a bit with the noise as this is a loud machine which I don’t mind too much but would like it to be a little quieter. I roll it over a thin rug while it’s in use in front of my sink and that helps a lot too.
