Where's the lighbulb in the Radar-Ranges?
Cybrvanr
Jan 23, 2005
1,287
I took the top plastic cover off my RR9 thinking for sure the lamp would be behind there, but there's nothing in there but the "stirrer" and a wire mesh that the radiation goes through. Where's the light bulb in these things, and how do you get to them?
There should be a narrow access plate secured by one screw on the back of the unit, in the upper-right corner (at least that's where it is on my RR-700). Unplug the oven, remove the screw and the plate, and there's the bulb. Good luck!
The bulb is not a threaded mount, but
is a push and turn, or "bayonet" mounted bulb. Some hardware stores have them, or try a sewing machine or vacuum store...they use this sort of bulb in high vibration applications.
Lawrence/Maytagbear
(Who has a 1986 RR-700)
Found it! thanks guys! That looks like the same lamp that's used in the "headlights" of some of the vacuum cleaners too!
