Which washer and dryer you you own?
Maytag Neptune MAH4000 washer/MDE4000 Dryer. BTW That set replaced the 1984 WP Design2000 washer that had a horrible time balancing bedding and jeans loads. The WP dryer was way too small, so it took extra passes to thoroughly dry heavy items.
KitchenAid "Superba" KAWE760 washer & KEYE760 dryer
Fisher & Paykel SmartDrive GWL08 washer & DE04 dryer (living with grandmother)
Fisher & Paykel Intuitive Eco IWL12 washer & SmartLoad DEGX1 dryer
Frigidaire WO-65 washer
Maytag A206 washer
Maytag A906 washer & DE906 dryer (in coppertone)
Whirlpool Calypso GVW9959KL0 washer
GE WWA5600B washer
GE WPSR4130 washer & DS4500E dryer (eeeeeek!)
GE WWA7400P washer
Whirlpool Calypso GVW9959KQ1 washer & GEW9868KQ1 dryer
Frigidaire WD-A washer
custody of Whirlpool LE5790XP dryer
and probably custody in a couple weeks of Whirlpool LE7800XP washer
Maytag Dependable Care
from 1997:
Washer- LAT9806AAE
Dryer- LDG9806AAE
I got them about this time of year, too.
Three apartments later, still running like new.
I have been very pleased with them and their performance.
Lawrence/Maytagbear
This is my Whirlpool set for the last 8 years. Not one repair on either one. Pretty happy with them, except washer is a bit noisy.
Serge
Theo, You have a nice set up there.
I particularily like the very neatly assembled platforms so perfectly fit to the appliances. Did you make those?
I want to eventually make some type of platform for my Duet washer. I know that it is so important to have them level. Do you ever have a problem with your machines vibrating on those?
They look so well put together. stright edges, etc.
kenmore 80 series, used i bought it off a nice lady on craigslist for 100 bucks,i have NO complaints, i love it! wouldnt change a thing about it!
Sadose
So, I maybe will buy this washer, only have to wait until the drum bearings of the AEG Lavamat 78800 are finally completely broken.
One last question:
What did you pay for it?
I have a Zanussi TCE7227W Dryer, its the best dryer i've had. Its really quiet and the sensor works perfectly. Its also a handosme beast, much nicer than the new look ones :-/ In my flat there is also a Whirlpool AWO/D 5516. It does the job, and i'm chuffed the landlord didn't just plonk in an cheapo Indesit.
Erik, the platforms are homemade. I made the one under the dryer more than 20 years ago to support a stacked set of a Miele washer and the dryer in the picture. My initial idea was to leave the platform standing on it's wheels but this proved to be too unstable and so I added the wooden supports. In that configuration I had no problems till the washer died. When I bought a new washer earlier this year I made a second platform. As the wooden supports were already planned here from the beginning I placed the wheels such that the supports would fit better under the platform. When I want to move the machines around, I use a small jack to lift the platform, remove the supports and lower the platform on it's wheels.
Here is a run down for my family
My mother had a 35 year ould A806 Maytag with a 2004 Whirlpool dryer
We have the 5142 Kenmore front loader built for Kenmore purchaed in Feb of 2005 and a TOL GE dryer from 2002
2 sons and wives and 2 daughters and husband all have the stacked GE (fridgemore) front load all bought at the same time as a scratch and dent for 395.00 a set.
Last son and wife has the gallery front load Frigidare with the controls on top and a now broken BOL GE dryer
Last daughter has a Frigidaire 2140 with matching dryer
Hey Theo,
Thanks for the pic. Very well put together. Those blocks even look sanded on the edges. Your system of adding wheels is well thought out. It also saves on wear and tear on the machines themselves when they get moved as you don't have to shove and yank the machine, taking a chance of damaging or denting.
I like the clean geometric styling of your appliances. So reminescent of styles we had here in the late 70s and 80s.
Another question for you. In your first pic there appears to be a basin between the washer and dryer picture and on top, what are the bars and the blue form fitting piece on that? looks interesting.
No detail goes unnoticed...
Erik, the blue thing is a drying rack that can be hung on doors etc. For a neat result when sawing timber I can recommend the Japanese saws. I have used the one pictured here for making the wooden supports.
Dyson
Hi Folks,
I am the proud owner of two TOL Dyson washers the first is my CR01 Memory the second is my CR02 2 Drums Allergy. You could say they are modern classics as sadly they are no longer made. I just love my Dysons; the CR01 Memory the older of the two is my daily driver and has completed more than 6000 cycles to date.
David
Washer is a Frigidaire GLTF1670AS0, vintage 2002.
Dryer is an electric Whirlpool "Imperial" series,(LE9200XW) circa 1990. Sucker refuses to die! I can't imagine what I will eventually replace it with..don't want to think about it.
I saw my identical pictured above GE Filter Flo at the Habitat Restore today for $40 I believe. Can't have two now. I was there to pick up a Maytag vertical a/c for my sister, near new for $50
