whirlpool A/Cs
I have a few whirlpool ACs;
'69 i grabbed at the dump in 1983 and fixed-it had an"inside-
out"delco motor with a shorted winding,replaced that with a
different salvaged motor-had to remount the condenser fwd
about 4"
(4)small 5000 btu units-'74,'76,'80,'92
'84-8500btu IIRC
'92-8500btu IIRC,almost the same as the '84 which is almost
the same as a '72...
also have quite a few other ACs,a special fave is a big 220v
GE from around 1958;very heavy it has a huge,low speed,4-pole
compressor and the 3 louvers that can be turned to direct the
air.It's a little beat up and pulls some amps,but man does it
run nice(and puts out the cold!!)
