A friend of mine wants to know if it is possible to make a full size belt drive spin as fast as the portables do, and if so, how could it be done? if anyone knows feel free to write.
- Nathaniel S.
Because what could possibly go wrong in running a machine faster that the manufacturer has specified?
Wouldn't it just be easier to put in a motor that is double or even triple the speed? Maybe even do double pole or triple phase depending on how much action your clothing needs.
If double pole or triple pole is necessary you could use the single motor controls from the timer as an activator for a relay.
Paint some racing strips on the front of this 1970s-1980s belt drive, maybe "lift" this bad boy 3-4" with industrial grade cabinet feet, blue leds around the bottom perimeter, leds on the console, gang graffiti on the sides.....
