norfolksouthern
- Joined
- Apr 1, 2009
- Messages
- 544
Dropped by the Salvation Army earlier today, and found a harvest gold Whirlpool portable washing machine with the surgiator agitator. I had a Kenmore dual-action direct drive many years back, and really liked that machine. I hardly come accross these, as all the ones I saw on Craigslist were newer, with the electronic controls. Nice, I though! So, I bought.
I got it all rigged, and plugged it in. No problem getting through the cycles, the pump works fine. Water levels, all there. I spun out a couple towels, and they're damp-dry, so it seems to have plenty enough power.
But I ran into a little snag. There was rust comming out on the first drain, so it must not have been used for a while. On agitation, it drains constantly no matter how high I hold the hose. I think there's something wrong with the pump staying engaged during agitation. The wig-wag, perhaps?
Anyway, I pulled out the agitator, and took out the inner tub. Then, I cleaned the outer tub which has some rust spots. I think I can get some Rustoleum to handle that, as it's just surface rust. But I would like to remove the outer tub completely. I started by removing the three base screws, which I though was holding it in place. Apparently not, as it wouldn't budge as I was pulling it up.
Question: Will I have to turn the washer completely upside down, and remove the whole transmission before getting the inner tub out? Or, will it work free eventually? All the screws were easy to remove, it looks all well-lubed and nothing appears to be stuck. So I'm assuming it must be in the design some place.
Any thoughts?
NorfolkSouthern
Any thoughts?
NorfolkSouthern
