jeff
Hi! I’m trying to A) identify this washer’s model number and rough age and B) fix tub out of balance and the machine walking when spinning on Normal cycle. It successfully spins on Delicate. I don’t see a model number anywhere. I was looking at replacing the machine with a Speed Queen or Maytag Commercial, but after some research would like to extend this one’s life indefinitely and would appreciate any advice.
Background: I bought this used when getting divorced 2 years ago in a ‘need something solid right now’ situation. I got it from a used appliance place in San Antonio, I’m pretty sure the owner was buying machines removed by Sears, Best Buy etc, cleaning them up, painting as needed, and parts swapping to make whole machines. When I got it home and installed it (upstairs, in a 15 year old frame house) on every cycle’s spin, the inner tub would hit and machine walk. It didn’t matter how well I balanced the clothes, it would go out of balance. I did some research and replaced the below items; after replacing them I was then successfully able to use the Delicate cycle without it banging or walking.
Suspension spring 63907
Counter balance spring W10250667
Washer support tub suspension pad kit 285744
I’ve included some pics of the old suspension springs plus the old and new wear pads.
I’ve continued to use Delicate for 2 years, but would like to get Normal working without tub banging. Even if I perfectly arrange the clothes it bangs on Normal.
I’ve also looked for the model number so in the future I can order parts easier. I’ve had no luck. I had assumed maybe the model number was removed during painting from the bottom of the lid, but then I saw a similar machine on Craigslist locally also with no model number under the lid.
Any help or thoughts would be appreciated!
