Clothes, dryer intake, air filters
Could be a good idea, of course the course filter like that. Doesn't even get 2% of the pollen going through it, but it would help keep the inside of the dryer from being excessively filled with Linton dust, especially when a dryer was not vented outdoors or poorly vented.
If you care about pollen getting onto your clean, damp clothing as they dry, you should have a very good high-efficiency air filter to completely clean the room. The dryer is located in. My laundry room is in an area of the house where the main furnace air handler runs 24 hours a day witha high efficiency pleated filter in an electric static filter after that it's also wonderful because when you're folding laundry and everything, there's an intake vent in the laundry room so dust just never accumulates it sucked up and filtered out.
The big problem with this filter that Maytag used as it should've been on the back of the machine where it might've had a chance of being seen cleaned occasionally.
The other problem is only about 70 or 80% of the air comes in through those vents in the back, the rest is drawn in around gaps all around the cabinet control panel, etc. like any other clothes dryer so it doesn't offer a full hundred percent filtration anyway.
John
John
