Whirlpool/Kenmore Design 2000 Thread
I posted a while back about how Whirlpool was taken to court by GE and Maytag in Canada about a patent issue regarding the dual action agitator. In the court case there is a paragraph about how Whirlpool was researching dual action designs, with one of them being a direct drive machine that had its own auger drive shaft. Meaning the auger in the dual action agitator would not have dogs to cog it around, it was powered by the transmission. Neat.
Thanks everyone for your replies, I've been busy these last couple days so I haven't had the time to respond.
John, thanks a BILLION for the pics! I never knew how much different on the inside that one is compared to a later model WP. The tub design reminds me of that off an older Norge. Is that the original fabric softener dispenser?
I agree with chetlaham, a YT video would be nice. Who knows, it might even get a lot of views, just look at the view count on some of the other washer videos on there!
You mean concentric shafts, like how a wall clock operates? That could have been interesting...
"Concertic shafts? Never did happen." It did, in an experimental prototype that was never released to the market in the 70s. Read the link below.
Whirlpool when designing the dual action had concentric shafts where one shaft powered the agitator base, oscillated, and the other shaft was constant drive and powered the auger.
Heads-up if you didn't see it, Whirlpool's concentric-shaft agitator is featured in today's Patent of the Day!
(US Patent #4,068,503 for future reference.)
Here's one of the patent diagrams... there are several others in the patent document.
whirlpool direct drive
I've been wondering about the engineering and what went into the entire project for sometime. my former babysitter had a whirlpool direct drive which agitated at full speed the entire time during the regular cycle. I remember the low F tone coming from the motor during high-speed agitation which sounded cool. It had that chunka chunka sound.
I disliked that
chunka chunka sound. No doubt the gearcase clunking at the short stroke left and right throw limits. The thin light housing probably excentuated the noise. The motors were mainly quiet. The only cushioning was from the flexible coupling, similar the that found on the steering columns of Saginaw collapsible ones in 1965 through '96 rear drive GM cars and trucks. The motor mounts horizontal, and the gears transfer motion to the agitator shaft vertically.
The Whirlpool direct drive isn’t a bad sounding washer but this is something I can literally fall asleep to at the 5:05 minute mark
My new ‘63 Whirlpool has a very pronounced woo woo sound it makes when washing :). Unfortunately the hose that goes from the pump to the lint filter broke on me but hopefully I can get that fixed tomorrow since I picked up a new rubber hose at Home Depot today that will work. Will be up and running again later this week and this is the first repair to my new ‘63 Whirlpool Imperial Mark XII washer
Photo of my ‘63 Whirlpool Imperial Mark XII
Woo-Woo Sound From Belt-Drive WP Washers
This phenomenon only happens on models with the regular 1/2" wide notched belt, on the machines where it is most pronounced the belt is usually a little too lose and often worn, it is really a sign that the belt is slipping a little and probably should be replaced.
Just repaired my refurbished Estate 24" DD this afternoon. Good thing I was home. Noticed the washer doing a long spin spray rinse.
When I stopped the machine the water kept coming in even when I unplugged it.
I am not very mechanically inclined but I knew it had to be the water valve cold side was stuck open.
An hour drive away and a $37 part later and I got my machine back up and running.
Glory to God for giving me the courage and ability to tackle something I normally would not have.
Hardest part was lining up the cabinet to snap into place.
