markmc
Baseplate/ Centerpost
Hi John,
Making the centerpost part itself seems the easy part of getting the machine running again. I do see a fairly entailed procedure though to install a new centerpost into this baseplate correctly. My thought is, where you are in MD is about 7 hours from my home base in NH. I would gladly take the drive to purchase and pick up one of your baseplates. If this sounds OK with you, I'll see what works with my schedule and check back with you for what works. Would you happen to have any lower baskets for this machine? The one I have does have areas where the seal sits that the centerpost passes thru that are a little rough.
Hi John,
