Yep, that's the unit. You beat me to posting pictures there!
Pardon the length of this posting, but here's a bunch of stuff I've learned in 10 months' experience using this machine for everything except large items such as big blankets (for which my large Hotpoint TL continues to serve). Just so you have the information before getting started (otherwise there is a learning curve).
There's a small modification you may want to do, which will make it run really quietly. The rear panel is plain galvanized sheet metal screwed to the back of the housing. (It has somewhat sharp edges so handle it carefully.) Get some duct tape. Take off the rear panel. Line the edges with a single strip of duct tape folded over each edge. When you put the panel back on (careful, do not overtighten the screws, the sheet metal on the cabinet is thin, you don't want to strip the screw holes), the duct tape will form a slight cushion between the metal surfaces. This in turn will eliminate the vibration noise that would otherwise occur with the standard metal-to-metal contact, and it doesn't look bad either. I suggested this to Danby and they said it was an interesting idea, they might do something with it.
Note also, the manual says 10 lb. capacity. Realistically it's 6 lbs., which divides neatly into two 3 lb. loads through the spin dryer. (I have yet to see or hear of a compact washer of any kind that will hold more than 60% of its rated capacity; the issue is the tendency of stiff articles to take up relatively more space in a smaller drum in order to move around.)
Also note, the "gentle" setting is plenty strong enough for almost everything. The only time I use the "normal" setting is with a full load of nothing but white underpants & white socks but even then, "gentle" will do the job perfectly well. I tend to suspect the "gentle" cycle is also a bit too vigorous for *really* delicate items, but I haven't tried that yet (like, dood, guys don't have lace undies!
. The agitator looks deceptively simple with its four plain-Jane straight vanes, but in fact works quite well. Note, the "normal" setting, when used with larger items, may cause some splashing if you leave the washtub lid off.
Don't wrap pant legs around the agitator; bunch up your pants and toss 'em in on one side or the other and they'll do fine. Same case with long sleeved shirts. Same case with any compact washer having a standard American-style agitator.
I don't leave the fill hose attached when the machine isn't in use. Instead I unplug it from the control panel (the fittings are quite durable enough to deal with constant plugging & unplugging of the fill hose) and let it hang vertically from a hook in the kitchen, so it will dry thoroughly inside. This way only the discharge hose remains attached, so there's one less hose to think about when maneuvering the machine back from the sink to its storage spot next to the counter.
The sink adaptor that came with the unit fit my sink faucet slightly imperfectly such that it wouldn't stay on all the time when the faucets were turned up high, eventually the threads stripped. I went to the hardware store and got a new one for a few bucks which fit perfectly and has stayed on with no problems. I suspect the issue here is a slight measurement difference in the original adaptor, but since it only costs a few bucks to remedy it's no big deal.
Remember to clean out the lint filter, which is located in the agitator post (a quarter-twist of the top part will release it).
I've never found it necessary to remove that coarse-items filter at the top rear right side of the washtub, or the one at the right rear of the agitator; lint does not build up in those places. Though if you do, don't use a sharp object to pry it out, use a blunt object such as a butter knife or similar.
Re. water fill: turn off water supply manually; the overflow drain does not automatically turn on the water pump all the time (if you briefly switch the drain selector to "drain" and back again, the pump will stay on to handle overflow).
Keep hot water temps at or below whatever it said in the manual, I think that translates to 140 Fahrenheit if I recall correctly. Water too hot will cause deformation of the plastic tubs; this pertains not only to the Danby TT but all other washers w/ plastic tubs. (Yes, the folks who prefer stainless steel will laugh, but OTOH if you need to sanitize a load, there's always bleach or hydrogn peroxide.)
Re. the spinner: an evenly balanced load will spin almost silently. Most of the time loads are slightly unbalanced so you get a certain amount of vibration though it's still pretty darn quiet. However if you have a serious unbalance and hear the spinner bump against the inside of the compartment, open the lid immediately and repack the load; you don't want that thing bumping aound at high speeds.
And *always* put the spin mat (that circular plastic thing like a slightly warped frisbee) in on top of the spin load, to prevent socks etc. escaping and causing much mayhem.
I don't think it's possible to defeat the safety brake attached to the spin lid; it's a very clever design, opening the lid releases the cable, which causes the brake to be applied.
I've been thinking about trying to order a replacement washtub lid and spintub lid, and cutting large circular holes in them and mounting some 1/4" thick plexiglass (perspex) in there with white nylon screws, to provide visibility with both lids closed. Then I'd put the replacement lids on and keep the originals for spares if ever needed (and if I screwed up the modification, it wouldn't be a loss 'cause I'd have the original lids in hand to put back on).
Note, this unit is not designed for Hoovermatic-style extract/spin rinses. If you try putting water through the spinner while it's running, it will bog down the motor and I suspect that could cause the motor to wear out prematurely. However, what does work is: Don't snap-shut the inner spin lid, just leave it casually closed. Unplug the water hose; and when the spin motor stops and the spinner is coasting to a stop (which takes about a minute), turn on the water, lift the lids slightly, and poke the water hose under the outer & inner lid, and direct the water into the center hole of the spin-mat. This will a) re-soak the load for a subsequent spin, and b) cause the spintub to slow to a stop more quickly; after which you can turn off the water and set the spin timer for another minute or two. This is as close as you'll get to an extract/spin cycle, but it works quite well and you'll see the results with the suds that get discharged each time you do this. Caution, do not stick your fingers in there or let the hose contact the moving spinner; at high speed it can cause serious injury.
No mixed loads of towels *and* plain sheets; this combination a) tends to wrap around the agitator, and b) can offbalance the spinner badly. In fact this combination is not recommended for large TLs and FLs because it can offbalance them pretty badly during spin also.
To encourage suds, stick the drain hose over the edge of the washtub and switch the pump on. Suds are caused by water falling into water more than by agitation as such. This is useful for determining if the amount of detergent you're using is adequate (i.e. "enough" suds but "not too much", is a useful indicator). You'll discover that you can use less detergent than normal with this machine and get the same level of clean as you would otherwise get with more detergent; I think this has to do with the more efficient spin cycle.
Also do not drain the washtub while spinning; the manual says that the water could back up from the washtub into the spintub which is trouble; instead, drain the washtub while moving the load from washtub to spintub.
Leave the lids off/open overnight after use to allow everything to dry out; same as with any other washer, to prevent mold from forming.
Fast wash procedure: 4-1/2 lb. load, wash for 6 to 9 minutes, move to spintub, spin for 2 minutes while re-filling washtub, move to washtub, use overflow rinse for 6 to 9 minutes with incoming water at 1-3 gallons/minute (discharge will be intermittent as water level fluctuates slightly), move to spintub, final spin for 5 minutes, done in less than 30 minutes. A decent TL will do twice that load in twice the time, so the time-efficiency is comparable or a little better. A large TL (12 lbs.) can be more time-efficient depending on cycle, but many users of compact machines don't have space for a large machine. (Note, the point of the 4-1/2 lb. load is, that's the max capacity of the spinner; so you can put the entire wash load in the spinner at once, which saves time compared to a 6# wash load that divides into two 3# spin loads). If you're doing multiple loads in one day you can wash or rinse one load while spinning another; more time-savings there; this can be as time-efficient as a large TL.
If you have more time: let the load soak for 10-15 minutes before turning on the agitator for the wash cycle; this is a "free" soak cycle!
BTW, maximum power consumption (measured) is quite low, so this unit is very suitable for houses on offgrid power. Agitator is about 250 watts, spinner is about 150, pump is about 27. Total power consumption is an amazingly low 0.06 KWH for a 4-1/2 lb. load, which is about half per pound compared to Hotpoint TL; and should be even more efficient with a 6-lb load (I'll run that test this weekend).
