>> First, most bearings favor only one direction of operation; top-loading machines require the bearing to
>> both resist forces side-to-side (from spinning or rotating) and up-and-down (to support the basket and/or
>> agitator/impeller). No bearing is excellent for that -- roller bearings would not do well with supporting the
>> weight, ball bearings wear out faster in this mode than in other modes, and the bearings that set rollers at
>> a 45 degree angle, which in theory would help in this mode, are not very good at hight speeds for spinning.
Is that really a problem though with proper bearing selection?
For example, tapered roller bearings handle all kinds of continuous hard loads in service as automotive wheel bearings, including high side loads at speed. I'm not a subject matter expert, but a quick look at the SKF website shows all kinds of tapered roller bearings with extremely high speed ratings... such as the SKF 30202 which is rated for 17,000 RPM use with a do-not-exceed limit of 20,000 RPM. If our washing machine baskets could hold together at that speed, we wouldn't need dryers at all!
