Besides risk of sudslock
There has been considerable debate in at least commercial laundry community over extracting between rinses for h-axis washers. This has gone on largely ever since "washer-extractors" came upon the scene in 1950's.
One side feels that extracting wash between rinses forces dirty water through laundry which will act as a strainer. In their minds best to rinse via high dilution which is achieved not just with high water levels, but fact each successive rinse bath is in cleaner water. This of course means using relatively large amounts of fresh water.
OTOH those who favor any sort of extraction (even if short pulse of low speed) feel it enhances rinsing and makes that process faster because less such cycles are needed on average.
The older SQ washers at local laundryette didn't spin between any of the rinses IIRC. But then again maybe they did before the final rinse, cannot recall.
The newer and more "energy efficient" SQ washers have short pulse spins between first rinses then a really good one before final.
Obviously if you don't extract wash fully between rinses the load will absorb less water in subsequent cycle. This is one reason why not extracting between rinses means using more cycles. You basically are (again) counting on dilution to get most of soils, chemicals and whatever out of the wash.
Interestingly on most modern domestic front loaders various "sensitive", "no crease", "easy cares/permanent press", etc... cycles do not extract between rinses. This and or maybe there is a gentle pulse or slow spin. Recommended recommended under loading (usually half of capacity)for some of these cycles increases the water to load ratio which should result in better rinsing.
Tunnel washers that are rapidly coming to dominate commercial laundry industry do not extract between cycles; they cannot by design. Instead laundry is moved through progressively cleaner batches of water then finally extracted.
