Onto Topic:
If you aren't getting any fragrance out of the tumble dryer, you may wish to try using the "Less Dry" setting (For Automatics), Less time or a lower temperature/different fabric selection. Based on what is written above, I would avoid the tumble dryer sheets like the plague.
For best results, use a GOOD quality softener (not too pungent, one that doesn't give reactions/headaches) in your washer. That way, you aren't ruining clothes or the dryer, or the washer (see my above post!). Any buildup in the washer is "washed away" with subsequent Hot/Warm washes. If you are really concerned, rinse with warm water, if possible.
