Widescreen/HD TV; your take on it
arbilab
May 1, 2011
5,253
Ft Worth TX (Ridglea)
Most everyone already made this transition. I waited until my tuber started folding over on the top and NEEDED replacement. A couple weeks ago. Got a Sony 32, anything bigger would block the bedroom door in my HUD geezer poorhouse apt. By switching wires around it will also play DVD in component mode and VHS in composite mode, as well as cablebox HDMI and antenna. Many/most will not do all that.
'Retail' was $350, I paid $300 including tax and stuff you're supposed to buy like cables. From a mom/pop SONY store. Looked at some of the box houses online, they wouldn't tell me what the inputs were. It mattered.
Well now I can read not only the cable guide which Charter recently scrunched down to illegible on SD, but also the drug warnings on commercials which occupy almost half of cable airtime. But guess what? Three Stooges films actually have EDGES. Not to mention the ability to closely approximate newscasters' pore diameters in fractional millimeters.
Overall I'm quite pleased. Much less squinting. I can read Nurse Rached's badge on Cuckoo's Nest, though of course nobody needed to. Virtually all that squirrely NTSC aliasing on fine detail like ties is gone, even on shows originally recorded in NTSC. I dunno zackly how they do that.
Not all the trans-format artifacts are gone. Sometimes, filling the screen gives you fat people. There are pan/scan versions of widescreen movies that really don't look right no matter which button I push. Mostly I just leave it on 'full' and let the black bars fall where they may.
With LED backlighting, all the fluorescent gamut artifacts are gone. That was a big colorimetry hurdle for flatpanels, particularly since the biggest gaps fell within the fleshtone range.
As the guy who spent most of the 80s defining colorimetry for half of Oklahoma, I expected to have more bones to pick with digital/flatpanel displays. Maybe I waited just long enough.
I think Sony was a good choice. If I had to do it again that's what I'd get. I have a 32" Samsung in my bedroom. Downstairs there is a 52" Sharp Aquos. I don't think you would like the Sharp, it's LCD and the backlighting is quite uneven on it. It's an earlier model - 2007. My Samsung OTOH has the LED backlighting and it's pretty even, I'm quite happy with the picture quality after spending a couple hours tuning it one day.
The black boxes is simply because of the SD content. Changing it to fill the screen would distort the image in unpleasant ways (like you've already seen) so I just leave it alone as well.
I don't think I would ever want to go back to a tube TV. I enjoy watching my HD shows and picking out every last detail on the sets too much.
I'm still using my 1990-something (IIRC) Magnavox CRT set. It works, although there was some drama last night when I tried watching a DVD. Not the good drama contained in the DVD content, but the set was acting up. Fortunately, it was only a cable issue.
When this set does die, it will likely be replaced with a similar CRT. They are so much cheaper than a new set. So are CRT TV cabinets--Goodwill charges insane prices for crap furniture, but I have seen real wood 1980s TV cabinets drop as low as $9 there. Much cheaper than a modern flatscreen TV stand. Plus I can shut the door, and not see all that tiresome plastic.
I suppose a newer set would have pluses. One for sure: it could be lighter/easier to move. That said...CRT works just fine for me. In recent history, most of my viewing has actually been old TV shows, which have a picture format that ideally fits the screen dimensions!
Past the possible picture quality advantages of LED, there is also the hope that the LED back lights will last longer. Perhaps a vain hope for longer TV service life, given how electronics are now throw away, but hope is always nice...
As I see, Sony TV's are a great choice for the bang of the buck!
I have 2 Sony's Bravia KDL-46XBR6 and 52XBR6 from 2008 and still working flawlessly.
This vintage new sets was the best TV's for its time!
Setting the TV's (Display Preference) takes a few minuets to get it right.
1: Make sure TV Ratio is set to (Widescreen 16:9).
2: TV resolutions is set only to (1080I or 1080P) or the highest setting for your set!
3: Video Native (OFF) Screen Format set to (Pillar Box).
I'm not sure if your TV has these capabilities but these settings work best for perfect viewing without all the odd images that drives me nuts when I go to Dr's offices or other common TV viewing areas...
The last photo is pillar box in Native form on (Unaltered).
Keep in mind that TV stations has mixed broadcasting so bar lines on the end will be shown for certain shows!
Enjoy your new set!!!
Welcome to the world of HD, Rick! I was a late adopter, too, having finally kicked my late 1990s 35" Toshiba and 26" RCA to the curb during a city-wide cleanup last May. I purchased two identical LG's, as that's the only brand available locally.
I played with picture adjustments quite a bit but was never really happy with the results. Then I learned that Consumer Reports online provides optimal picture settings (which go deep into secondary menus) on models they've tested. I set the controls to their specifications and picture quality improved by orders of magnitude. All the hit-and-miss futzing in the world wouldn't have yielded such an excellent picture.
If you provide the screen size and model number, I'll gladly check online for your new Sony's optimal settings.
It's awesome you were able to purchase from a mom-n-pop store, too! I love supporting those businesses. They bend over backwards to provide great service.[this post was last edited: 11/27/2015-22:14]
Our 32" Sony Wega set that wouldn't turn on after a power failure finally turned back on again. This is the 225lb set I discussed in a thread a while back. If you turn the set off, it takes three days to come back on. So we just leave it on all the time. Every few weeks we get a power failure and the set turns off and it's 3 more days till it turns back on. So we have been using a Hitachi 19" portable set when that happens. The Hitachi is from about 1983 or so and gets a nice picture, for a CRT type of set. Nice color on it.
The problem with the Sony is a IC is bad on it. The IC is not in a socket, but wired into the HV circuit on the set. One local shop said it's expensive to repair because the IC is in a difficult to get to location and there is a lot of soldering to be done to put a new one in. So it's time for a new set. We bought the set in 2003 and I figured that for what we paid for it ($900) it should have lasted longer than it has. But when it's working, it gets one of the best pictures around.
So we are looking at new sets, probably in the 40" range. We want 120Hz or above too. We'd go with Sony again, but we have heard that their new sets are pretty unreliable and even with a service contract getting Sony to fix them is like pulling teeth. I'm not a fan of LG or Samsung. I'd look at JVC, but it's been at least 20 years since I have seen a JVC for sale anywhere. Do they even still make televisions?
Can't say that JVC makes ANYthing for the US market anymore. The electronics market is in no less turmoil than the laundry market.
I swore off Sony when their 7yo WEGA became unserviceable in 2009 due to lack of parts. Great pic and sound but couldn't be repaired at ANY price. Figured 'buy cheap cuz I'll just have to throw it away anyhow'. But when they gave me $$ off MSRP on a Sony with the right input array, just shrugged 'can't beat that'.
First thing with any Sony.... and most everybody elses'.... is they ship in 'display mode' that makes them look "bright" in the store. They've done that for decades, despite the exaggerated contrast (set to 95/100) makes them uncomfortable to watch and even defocuses CRTs. At 85 it's still too bright since advertisers figured that blinding you was a way to get attention, but just right for films that have an actual exposure range. I've got 'color' set one notch down and 'tint' set one notch red.
Have to say, with decades (feels like centuries) watching studio color, this set makes deep red shades (car paint) I've never seen on CRT.
Just happy it's not 'appalling' like the earlier CFLs were. BTW, whatever happened to plasma? That was the hot (literally) patoot a few years back.
Swearing off a brand for this sort of issue is something I might do in a moment of high dudgeon. That said...it's probably not a "Sony" issue. It's a "way the electronics industry is these days" issue.
Even high end audio equipment that cost $$$$ new may not be repairable as long as one might think it should be given the price...
No idea, but I wonder too. I don't think I've seen a plasma set recently, although I only see new sets places like Target. That said...I suppose LCD-type technology simply improved so much that plasma no longer remained as appealing.
Another gripe I have with modern TV sets is the high glossy black frame most companies use. An idea perhaps stolen from Apple. No matter where it comes from, I hate them--partly because I find them too noticeable in my peripheral vision.
I do note some companies have models that have a flat or at least flatter black now, and if buying new, that would be one item on my checklist.
There are still Plazma Sets Around
but they are usually found in higher end places where they sell complete home entertainment systems.
I think one of the problems with the plasma televisions was power consumption and heat. I recently held my hand about a foot away from the front of the screen of a plasma set and it felt like an oven cooking. It takes some serious energy to make that much heat. Plasma sets use much more energy to operate than LCD and LED sets do.
Like I said this Hitatchi 19" CRT set we are using while the Sony makes up it's mind to whether or not it's going to turn on again was built in 1983. And the picture on it is very good still even for a CRT set, even after all these years.
Where we get our ideas about Sony reliability is that a friend of ours installs high end media rooms. They carry all the major brand names. But he said that for the past three years they have had so many problems with Sony sets either turning themselves off and not coming back on or the screen goes bad and needs to be replaced. Last year about 40% of the Sony sets they installed went bad. So they are pushing the LG and Samsung like everyone else is. Our friend thought Samsung was a bit better than LG. And just because you have an extended warranty on your Sony set doesn't mean that Sony is willing to help you out either.Just go to the back of the line like everyone else.
I thought about JVC and Hitatchi, but they have even more unreliable sets than Sony has.
It seems that sets are divided into different classes these days.
You have your high end televisions such as LG, Samsung and Sony and Panasonic
Then you have your middle of the road sets such as Visio, Polaroid and Hitatchi.
Then you have the BOL sets, HISENSE, Westinghouse, Element, etc.
I wonder how many different television companies there really are making televisions. Like are there only three of them making all the sets made?
And then there are the "holiday specials" that are made specifically for retailers to sell at door busting prices during the holidays. These sets may not have many features on them and some are even made from cheaper parts just to meet the price targets.
- Red Colours on New TV
As I understand, on the CRT tubes, Red is the first colour that starts deteriorating followed by blue, IIRC.
- Plasma TV
We've got a 42" Panasonic from 2007. It may well be on its way out, there is a spot in the centre which is brighter with static at times, and makes some images look like there are "bees" or other insects floating around.
The heat output is significant, but not an oven. Still it would be equivalent to a halogen light or two, and uses at least 400w/hr.
Picture always has been very good, bright and warm colours and all that stuff
- HD/SD Signals Themselves:
This is where I have something to say. Its all well and good selling TV's capable of this sort of quality, but only if the broadcasts are actually *IN* the sort of quality it ought to be. Thanks to the stupid number of TV stations on either Free-To-Air or Cable setups, they have to reduce the bandwidth of HD to at least half of what it ought to be. To fit in more HD channels, SD is squashed down to "barely-so," and they put more of 'them' in too.
The result is pictures turn to pixelated mush in action scenes and anything more than still video. MPEG compression used for TV doesn't help, as it relies on 'dropping frames' to save on bandwidth.
With the new "UltraHD/4K" business, I will be interested to see if they find another broadcast mechanism, or continue to sell the notion of "high quality" with the footnote (*only when you use pre-recorded items like commercial BluRays will you ever see this sort of quality again, sucker*).
The first flat screen we bought was a lower priced AKAI 32" at an after Xmas sale and I can't complain about the picture in fact I've never seen anyones flat screen LCD tv that truly has a terrible picture. It has terrible sound though so I hooked it up to my old JVC receiver and speakers.. What a difference.   We got a 40 or 42" Samsung a couple of years ago and it's good as well, sound is decent but it's not hooked up to any external speakers and we're fine with it. The AKAI went to the basement.  What made the difference though was getting HD cable box which of course the cable co charges more for.
And now there's ultra HD and all these other things like smart tv's etc. but I'm not biting for now. We don't download or stream movies, do on demand, any of that stuff.  I'm waiting for January when a new broadcasting law takes effect here in Canada forcing the cable company's to start offering low cost basic packages and pick and choose extra channels instead of having to buy packages with a pile of shite you don't want just to get one you do want.
samsung UHD
Watched a new Samsung UHD,curved screen model and it was pretty impressive!I don't watch tv all that much,so that set would be way overkill for my watching :) my main flat TVs are a couple 2010 42" plasmas:one Panasonic the other sanyo,both have been good though the Panasonic has a little "burn"at top and bottom from store display,but not noticeable while watching.The TV I watch the most is my big 1982 zenith"space command"console:Once, when my brother came over on vacation,i noticed he kinda smirked at the sight of that big,old,'70s style tv,but all negative sentiment about it disappeared as soon as I turned it on-colors,picture and sound very good for such a dated looking set :)Back on the subject of modern TVs,seems OLED sets are out again-I kinda remember there were some avalible~2008,but quickly disappeared-short life of color accuracy one of the complaints of those early OLEDS...
Here in the US, the OTA, over the air free broadcasting of HDTV is not compressed. You only find a compressed signal on output from cable and satellite companies signals. So you get a better picture using an antenna.
At least this one was assembled on the North American continent (Mexico), albeit little doubt all Chinese parts.
The heat coming off it wouldn't melt a self-respecting Hershey bar.
Only artifact of the TV itself, somewhat narrow 'ideal' viewing angle. Though sitting aside it at ~60* like I am now, still quite good while shifted toward black. Already quite familiar with cable/digital artifacts, obvious even on the 19" CRT squintbox.
Model is KDL32R420B. Fiddled with the exotic menu settings, didn't find any uncompromising improvements. I've got a lot more time calibrating displays than Consumers has but I'd still be curious to see what they came up with. I did it with a scope to Tektronix specs. Even so, it took a couple years before the controlroom guys gave up trying to 'improve' on what the manual said.
To answer part of your question Rick
See link. I would suspect there are but a handful of makers, probably all in China, making sets these days.
