This is a new thread to avoid hijacking the oil heat vs. propane heat thread.
Replacement windows are nearly always a bad idea. (Sorry, but I'm in both historic preservation and energy efficiency.) With PROPER weather stripping and glazing putty in good shape you can get close to the efficiency of new windows with just single-pane glass. Add storm windows and you can get BETTER energy efficiency than new windows. Good storm windows increase efficiency even more. Finally, your window treatments (and how and when you use them) can actually play a big role in energy performance.
Read what Bob Yapp has to say about windows. I took his window restoration class and I've found through my experience that, crazy as it sounds, the old windows can really get some spectacular thermal performance. Historic windows are also made of components that are all pretty generic and are individually repairable/replicable, quickly and affordably. Repplacment windows are made from propriatary parts and are neither maintainable, nor repairable. The average life of a new window is about 15 years, then you throw it away and get a new one. Don't believe me? Go out to the suburbs to subdivisions built in the mid 1980s to mid 1990s (which originally had double-pane windows) and see how many original windows are left after 20-25 years. In my parents' subdivision (built 1986-1989) about 3/4 of the windows have been replaced.
This flies in the face of what you are told at Lowe's, Home Depot, HGTV, etc, but if you study the actual performance numbers it all makes perfect sense.
Please read the link attached, it explains everything better than I can.
Clear as mud?
Dave
Clear as mud?
Dave
