Wiring a PDE701
bluejay
Jan 22, 2013
873
Havre de Grace, MD
I'm relatively new to the site and have scored my first matching set of Maytags. I'm familiar with the dryer, as we currently own a DE700, but I've run into a bit of a stumbling block. The dryer was originally hard-wired into the house; I need to convert it to a 3 prong. Where can I find a wiring diagram for this (and subsequently, where does that random black wire attach to)? I've attached a picture of the wiring block; I imagine it's fairly simple, but our DE700 came already wired so I didn't have to fiddle with the electrical at all.
The set came from the thread linked below.
The dryer appears to have been used very little. There was hardly any lint buildup inside, and the drum and door seal look new. It does need new belts, which I already have; I believe it has the original belts still installed.
I also procured the original shipping container for the dryer. I was also provided with an automatic spritzer, which is supposed to keep clothes wrinkle free (I will never use this, but it's a cool piece of memorabilia). It came in a piece of the original washer container, which is pretty cool.
Any help that anyone could provide would be much appreciated!
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?48333_6
It's not a great picture, but here's the diagram for my '63 DE700.
I believe that with a US 3-wire cord the middle conductor is the neutral one; that would be attached to the middle terminal of the wiring block where the white wires from the dryer are attached. The other two 'line' conductors would go on the terminals where you see the black and blue wires (one to the black, one to the blue). The yellow wire looks like a jumper for 115v operation.
Please, if I am wrong, someone correct me!! I'm used to the Canadian four-wire dryer cords!!
Oh cool, thanks! I didn't realize the DE700 and DE701 diagrams were interchangable. I can check the back of our DE700 to see if the diagram is there. I can see the spot on the PDE701 where it used to be, but it is long gone. I've also got to try and figure out where the random black wire (pictured to the right of the block, just dangling in the air) hooks up to. I think it may go up to the timer, but I'm honestly not sure.
Hmmmm.... It might go to the fluorescent lamp ballast too. I'd suggest that you take the console cover off to investigate further. It likely came off when the old hard-wired cable was removed.
So the black wire goes to a secondary wiring block which appears to have a giant capacitor on it. The wires that come off of this go directly into the timer. The wire is the 2nd from the left. Also, you can tell I haven't finished the de-linting process. :)
Interesting side note, the PDE701 was made in 1962. Our DE700 was made in August 1963. The latter has the germicidal light, but the PDE701 does not.
Hmmmm... Now I'm not so sure where that black wire goes... I am going to hazard a guess that this the dryer with an automatic cycle rather than timed cycles.
Oh, redcarpetdrew, where are you??
It has the Regular, Wash'n'Wear, and Air Fluff on the dial, rather than the push buttons as on the DE700. You can kind of see the back of the 'Electronic Control' plastic filler plate in the top of the shot (which was covered in an awesomely thick layer of Jubilee Kitchen Wax).
Alright, she's wired up! The random hanging wire is labeled '20' and does not appear on the wiring diagram. I'm wondering if it goes somewhere else.
Yep, that's the one. All of the other wiring on the block matched exactly with the diagram, so I had it done in about 5 minutes. Once I get the black wire hooked up, I can clean her up, change out her belts, and move her from the garage into the house. :)
The DE700 & DE701 were made concurrently, the 700 being timed-only and the 701 having the electronic control.
It sounds like you already have this figured out, but here's the schematic for the 701 for the archives:
Update: I have the dryer completely wired and grounded; we'll be hooking her up next weekend. I decided to spend a little time inspecting the bearings and I'm glad we did, as one of them was almost completely dry. The motor has been reinstalled, the inside of the cabinet has been cleaned (there wasn't much in the way of lint build up), and all that remains is to secure one batch of wires and screw the back plate back on.
I'll post a picture once I have her up and running in our laundry room. Thank you guys for the advice on the wiring!
