Won't fill
kafooty06
Nov 5, 2017
71
washington
I need some advice I got a belt drive Kenmore washer that won't fill I have the water on checked twice and when I have it on fill it won't even make a humming sound . I checked the outlet and circuit breaker and they appear fine.
It may be a broken or loose connection to the fill solenoids or the solenoid itself is shot.  Does anything happen if you switch from hot to warm? How about at the rinse part of the cycle? Can you try selecting a cold versus a warm rinse?
Did some checking
I did try all temps and still no water. I tried all cycles and no power I thought it was the timer but that's not the problem.Im going to try checking underneath to see if there is and misconections thanks guys!
All figured out
Turns out one wire connected to the power cord came off . I opened the top and looked closely and sure enough it was not connected. I'm thankful it wasn't a bad part wew.
