wanthotwater
I have a AWN 2016 Speed Queen Washer. The water valve works for a few months, then hot water slows to a trickle. The first service replacement of the water valve was under warranty. The service guy checked the screens and hoses as well and showed them to me. Definitely the valve. Replaced and a couple months later, hot water is down to a trickle again.
Questions: Is there a way to work with this valve so it stops shutting off the hot water; like bypassing it somehow so it just runs hot and cold all the time? I could then adjust temperature at the wall faucet shut off.
Other than this water valve malfunction, I really like my Speen Queen Washer and Dryer!
Also, I keep the hot water at about 140 degrees, so should not be causing temperature issues.
