peterh770
Questions:
1) Since the tub is wider, might there be more of a chance of the tub hitting the cabinet when starting to spin, before the load balances out? Would the window be at risk of getting broken?
2) Would the same flume be used for filling and recirculation?
You might could adapt a 1-18 Circle Fill hose around the cabinet for filling and spray rinsing.
For recirculation, you need to aim the hose so that the target is the center of the agitator. The filter could fit inside the barrel. The heated, filtered water would be injected back into the load evenly around the top of the Energy Ring. You need a funnel for the agitator top like the top of a Philco Automagic agitator. Maybe a special flume attached to the lid to accomplish this? Or a special arm flume, independent of the lid, that you could raise for loading/unloading, and lower into place for viewing the action with the lid raised (or removed)?
