Work in Progress Westy D-102
bellalaundry
Mar 8, 2007
661
Niagara Falls, Ontario, Canada
I got this the other day. I thought I would share some pictures while the top is popped open. I've connected 110v to it.
I think it needs a new timer, relay, and motor intake filter.
The dryer works (except for timer) when I squeeze the relay together!
Guy
Guy, the timer escapment mechanism could just be gummed up. The timer on my 'ol 53 CD-6 didn't seem to run either, but I shot some WD-40 into the escapement and that loosened it up. It's been running for nearly 9 years now.
That's definitely what it says! Sorry Guy, I was incorrect then. So I'm missing something - how does the black line get power? Do these have a switch or setting somewhere perhaps to select 120V vs 240V? What John was saying is the same as I had learned, you have to put a jumper wire from one of the hot terminals to the neutral to get it to run correctly (or move the wire itself). But maybe Westinghouse did it differently?
Dumb question - have you checked the door switch? I remember having a 'no run' situation after moving mine. I managed to disconnect a wire to the door switch - it wouldn't run and I only thought of checking the door switch AFTER I'd practically torn the timer apart!
The dryer is functional, kinda. I put a couple of rubber bands around the relay so the contacts connect. So now when I turn the timer the dryer runs...heat, fan and drum. But the timer does not advance and surely the relay isn't doing anything other than letting the electricity flow thru.
Once I remove the timer Paul, where did you squirt the WD?
I'm wondering if when you pull to start, that it should actuate the relay to press the contacts together and get the dryer going?? The relay looks a little like a solenoid.
Whatcha think?
Thanks guys...
Guy, sorry this picture isn't better but what I did was first remove the timer motor from the timer box, then I shot the WD40 into the opening where the timer motor gear engages with the escapement. I turned the timer dial a few times gently and that seemed to free up the escapement.
The dryer should start by using the 'Pull to Start' knob, which engages a solenoid behind the knob. Make sure the knob pulls in and out without sticking and that the plunger(see arrow) fully engages when pulled out all the way. W sure loved to use solenoids on their laundry equipment!
So I got the timer motor to spin, sort of. I did soak it with contact cleaner and then some WD 40 (Thanks Paul) From a stopped position, it might start, but sluggish, then get up to speed. If I nudge it, it works OK.
Pulling the knob still does nothing, so I guess the plunger/solenoid isn't working. I have it compressed with a couple of rubber bands, so when I turn the timer knob it just starts the dryer. As for the door switch the dryer does shut down when the door is open, and turn on when shut.
So I'm thinking I shouldn't close up the top until the timer motor works well on it's own. Also, I don't know what to do with that solenoid?
Guy
