wp belt drive restoration
felix
Active member
Oct 29, 2019
32
São Paulo - Brazil
so, i recently started the restoration of this 1978 Brastemp (Brazilian Whirlpool) that i've found some mounths ago.
she received new spin tub and a new center post with new bearings!
'Molho' (Soak) did not count as a cycle?
Note the labels "3 Programas" (Cycles), "2 Velocidades" (Speeds). The three cycles are '1. Normais' (Normal), '2. Suaves' (loosely Permanent Press), and '3. Delicados' (Delicate), plus there is also 'Molho' (Soak) which did not seem to be included as a cycle like the others. I just checked Google Images of Brastemp dials, and saw the 'Molho' automatically advanced into the 'Normais'. Also, did 'Suaves' feature either a cool-down and/or high agitation and low spin?
reply# 5
exactly! the soak is part of the normal cycle...it takes 2 minutes agitating and 28 minutes to soak (on "super luxo" model) or 36 minutes (on "luxo" model). After soaking, the washer automatically continues to the normal cycle;
the "suaves" cycle feature low agitation and high speed spin without the cool-down.
after 1985, the "suaves" cycles has substituted to permanent press cycle thats
just switched for high speed agitation and low speed spin without cool-down. both cycles has 25min
