wringer washer pump help
dryclean1
Feb 23, 2014
84
Walton, NY
Hello friends,its the drycleaner. I have a visi-matic that I have used for a few years now without any troubles, just lately the pump stopped working and I had to gravity drain it. I havent gotten under it yet to take the pump apart, I hope the impeller isnt disintegrated like so many before. if it is I can install an electric pump like I have on my dexter quick twin. any advice would be welcomed. thanks the drycleaner
Hi Bill
Stan here..(the other dry cleaner)
I don't know about a Vistamatic, but seems I've seen a Maytag wringer rigged up with a modern elecric pump. If I remember, it was hidden under the skirt, and they had installed a toggle switch that tied into the power.
It be nice if yours has a easy fix without adapting it, but seems do able.
I think I fixed the pump
thanks to all for the advice, I took the pump apart yesterday and actually found that the impeller was fine but the Pump shaft was spinning freely in the impeller instead of it being fixed to the shaft, so when the pump ran the shaft was all that was turning. I epoxyed the impeller yesaterday and sealed the pump,so with any luck, it will work. thanks the drycleaner
