wringer
Do you agree with the following, Laundramatt???
Wringer "cycle"
1. fill washer tub with hottest water you can obtain.
2. add soap or detergent.
3. agitate empty to whip up suds.
4. put first load of whites in water.
5. re-start machine.
6. put lid on (or if you are one of us, leave it off to watch)
7. fill rinse tubs
8. check first load, if clean, stop machine and put first load through wringer into first rinse tub.
9. add second load and restart machine.
10. rinse first load by hand and put through wringer into second rinse tub.
11. rinse first load in second tub by hand and put through wringer into basket.
12. check second load to see if clean, if not,leave washer running and take first load to line in backyard.
13. take second load through wringer to first rinse tub.
14. rinse second load by hand for the first time and put through wringer into second tub.
15. put third load in washer (same water, but check to see if too dirty to use again...after all, you might have to pull the water from the well and heat it on the stove if you live in the country.
16. rinse second load in second tub by hand andn take second load to line and hang.
(repeat all of the above steps until you are finished doing the wash for your family of ten...........)
AND GEE WHIZ!!!!! TOMORROW YOU GET TO IRON IT ALL....
