launderess
If anyone can stand it, that is! *LOL*
Yesterday ran my little man through several loads and things went rather well. But then again no next to nothing about the normal operations of this machine, so thats' me for you.
A few things strike me as "off", and want to clear up what they could be so as to perhaps order parts in advice of Mr. Repairman's arrival. Call out service for appliances in our area is quite dear, and as this unit requires removing the entire cabinette (not an easy nor fun job one gathers), want to have as much on hand as possible. This way Repairman does not have to make multiple (and costly) trips and keep taking the machine apart. Or worse, leaving the thing taken apart lying about until parts can be found and installed.
Anway, back to the things one noticed.
Leaks: Have taken to shoving a large "wee-wee" pad under the washer before starting. Saves wiping up leaks and such, and one easily can tell where water is coming from by the damp areas.
Just as one was comfortable with the idea the pump was leaking, noticed there is a small amount of water from the center area (by damp spots on the wee-wee pad). After doing about six loads yesterday, tipped the maching slightly upwards and felt around the base plate area where the agitator is, and could feel dampness, not totally wet, just damp. There were also two small "oil and water" spots, about the size of a large pin head. Not total oil mind, but more like drops of water with bits of oil. Rather like salad dressing that has separated.
Next, sometimes while the machine is agitating there is a slight tiny rattle sound. Nothing major, and almost sounds like crickets.
Finally there is a slight "bang" or could be cluck when the tranny shifts from neutral to agitate. From what one has been able to research this could mean a rusting pin or low cam bar needing replacement.
On the bright side there is little if any "muck" or rust bits coming out of the drain water. So perhaps the original gunk was stuff built up between the tubs and pump that was disloged by my "acid bath" cleaning.
