db130
Active member
Back in 2016, I purchased a Maytag Neptune (MAH5500BWW) for $50 on Craigslist.
Other than it needing a new tub seal, it worked okay, and it has since run hundreds of loads. I mentioned the washer briefly here: https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?64365
It has never been a quiet machine, with it roaring like a jet engine during the final spin, but then the plastic outer edge of the tub started to grind against the door recently, leaving plastic shavings here and there. I ordered the factory seal kit (p/n 12002022) from a seller on eBay for $60.57+tax. I also ordered the two SFK bearings (6206-RS and 6207-RS) from a different eBay seller for about $12 each.
Both packages showed up this weekend and I decided to tackle the job yesterday. The inner bearing came off in one piece. The outer bearing came off in pieces, and I ended up having to cut a notch with a Dremel before it cried uncle.
I ended up cutting the handle of my 3 pound sledgehammer so that I could install the new bearing seal. I also cleaned the tub pieces while I was in there since they were both kind of gross.
I've run two loads since, and I didn't realize that the washer is supposed to be this quiet. I can just barely hear it from one floor up.
