Hi,
The motor on my otherwise wonderful machine recently started cutting out. I've replaced the brushes, which were worn out, but the problem remains.
The motor seems to energize (it hums when spin cycle is selected,) but only actually spins if I give the drum a shove. It then runs, but not at full speed, and sounds like it cuts in and out, as if there's a loose or worn electrical connection somewhere.
One other clue - the spin rpm speed control slider makes no difference to the motor speed...
I'll check the continuity to the motor, but in the meantime, has anyone got any suggestions.
The machine has been used once every week for the last 27 years with medium loads of washing...
Any advice really appreciated,
Thanks
Ritchie
Thanks
Ritchie
