zoom oil
No, but you’re right turban oil is better than WD-40, which is not really a good lubricant for bearings and such.
The main bearings in the front load washer are sealed ball bearings. They’re not really designed to be lubricated and once they’re noisy, they’re damaged and no amount of lubrication will correct the noise problem, sealed ball bearings almost always fail because they get water in them so you also need to deal with the water seal issue, etc.
John
WD-40 isn't a lubricant.  It's a rust-prevention solvent, suited for freeing rusted-stuck mechanisms and protecting metals from rust, to an extent ... it must be regularly reapplied for long-term protection.
My garage door repair guy after fixing a broken spring on the door told me to spray WD-40 on the springs every year ... to protect them rusting, not for lubrication.
The product name is an acronym for Water Displacement Formula 40.
I was told, or read somewhere, long ago that WD-40 washes away good oil when sprayed on motors and mechanism bearings and such.  Use it to free-up a stuck mechanism but then follow with a proper oil.
The blue 3 in 1 oil is a non detergent blend made for oiling brass sinter bushing on electric motors, small ones.
Its very good for that.
Ball bearings generally need grease, the lubrication requirements are different.
Even if you don't run the machine the grease will bleed out the oil in.
Its designed to do that.
Grease ages dries out.
If you become aware of a dry bearing sound you can get out a head of a failure and pull the seal out of a 2RS bearing and re-grease it.
Not all greases are compatible you need to use something similar to factory.
SKF for example seems to be using a polyurea grease these days that might not be compatible with older Lithium greases!!!
Turbine oils.
I have used some of those in plain bearing pumps with oil slingers.
VERY large pumps ( 500 hp ).
The light turbine oil I used last was intended for steam powered equipment and was tolerant of water.
There is a lot to bearing lubrication.
A site called Bob the oil Guy that might answer your questions a lot better than me.
https://bobistheoilguy.com/forums/
