2001WP Gold Powerclean Bobload attempt
whirlykenmore78
Silver Member
May 5, 2011
2,788
Prior Lake MN (GMT-0500 CDT.)
So a while back I made Lasagna and stuffed all the dishes into one load. Used the P&P cycle with Power Scour selected and Sani Rinse, no heat dry. Unfortunately I forgot after pics but sure as anything everything was spotless.
First 3 are the lower rack. Next 2 are the upper. Last is the Silverware basket and cycles/options selected. Yes the Whirlpool really did clean all of this in 1 wash. This is easily the best DW I have ever owned. PS, I have done loads like this many times and this machine NEVER fails
WK78
One thing and not to nitpick here, but, with any Whirlpool dishwasher that has the silverware basket in the door like the one has, one does not load pans in the front no matter how its angled. Plates go up front and that is to let the plates direct as much water as the basket can get to wash what's in it. Every Whirpool dishwasher I have ever had or used I loaded them that way and the silverware came out spotless. One has to remember that where the basket location is it is really not in the wash water "field" ...just the outer edges of both the bottom arm and middle arm. The Quiet Partner dishwasher I had in my house in Omaha also had the cutlery basket above it, which was kinda useless in my opinion since no matter how things were loaded into some items never washed clean so those items always ended up in the upper rack. The ones I used all had the JetStream Column by the way.
