Newer Whirlpool washers known for control board failures?
whirlpool862
Mar 3, 2025
180
Columbus, OH
I have four friends with newer whirlpool washing machines (WTW4950HW3, WTW4955HW3, WTW4816FW3, and WTW4957PW0), all continuously draining due to bad control boards. I hate how Whirlpool has declined in recent years. Three of them are 2023 machines, the WTW4957PW0 is a 2024 model.
My Whirlpool WTW4900BW0 washing machine is over 10 years old and the only problem is that it has a noisy bearing on the spin cycle, but it otherwise works fine.
Whirlpool says they’ve been recalled but some people said their whirlpool washer was only a few weeks old and only recently started the continuous drain issue.
If Whirlpool does not fix this immediately, they might eventually go bankrupt. Having a washing machine that has a control board fail within one year is ridiculous.
As someone else posted it, there's a massive pressure sensor issue that's caused Whirlpool to issue one of the biggest service bulletins ever for their VMW systems. The pressure transducer is failing on the model, causing infinite drain situations.
I think my company authored a solution to refurbish the boards without replacing the transducer. However, I am waiting on another 5 bad boards from a factory to try this fix before releasing the whitepaper to the public on it.
What Whirlpool's Controls Ought To Look Like
This is what people should be demanding and voting on from any appliance maker, in a metal Eaton or metal MTS style timer.
Perhaps contacts 12T and 14T would better suffice as drop on and lift off instead of drop off and lift on due to the motor making inrush, but that is an easy swap. 30 second increments btw- though 1 minute at 48 7.5 degree steps would be a better timer alternative.
From MTS's website:
Timers
Before anyone jumps on me for the spin or wash being to short, this is just one timer meant for a very BOL machine. The idea is to demonstrate the sheer amount of simplicity that could be built into a washing machine while being complemented with very over engineered parts and numerous overlapping fail safes.
[this post was last edited: 4/14/2025-12:56]
YES!
THANK YOU!
(I don't see how over-posting this issue does any harm. The public needs to know that Whirlpool has faulty control boards in their home appliances!)
I think that Whirlpool should build a basic washer which has a mechanical timer to match the basic dryers that still have one. They would sell very well. Give it Four water levels, and let the consumer choose the load sizes, and wash times. They could be coin operated too. Landlords and apartments would love a lower cost machine with less repairs.
@vacerator you might find my tough strange but i think if whirlpool wents to save themselve including the maytag brand they should return to basic i would see a vm or vmax machine base on the direct drive design but with the commercial grade qualaty of maytag and the technology of the speedqueen tc5 classic clean power with option to use atc temp or manuel temp selection true warm wash true hot wash not control by atc deep water wash and a deep rinse normal fill rinse when using fabric softner or not img-4984-2019-07-10_18-05-34_693187-e1562782094367-768x1024 (1).jpg
I have a WHirlpool washer wtw4816fw3 purchased in Feb of 2024 that now has the continuous drain issue. Called Whirlpool and was transferred and put on infinite hold. Website did not accept my request for service. Already paid for a service person to check and he said it is the board and I should forget about repairing. Is there a Whirpool service option?
It'll never happen... marketing wonks are notoriously stubborn, they'll go down with the ship rather than reverse course. I work for a company that once held over a 60% market share worldwide, and is losing ground every day because the marketing director decided to drop the reliable old design for a new pile of crap... It does have a few updated features -that no one cares about. I also think the EPA is all over manufacturers to get rid of selectable water levels, the user cannot possibly know where to set such a thing, gotta have it automated to assure the least possible water use. Reminds me of my Volvo with the lane keeping that can't really be shut off. Never mind there's a semi careening toward you, one must be in the very center of the lane, not hugging the fog line... Better to die like a Swedish hero than live as a coward! The design Whirlpool uses for those basic dryers is what, 60+ years old? They're still among the best built, reliable dryers on the market no matter what brand sticker WP puts on. It's nothing short of amazing they haven't been replaced with a cheap, throwaway design by now!
I will never take them seriously when they ignore planned obsolescence.
In response to original post #1
The fact that the 10 year old machine had no control board problems is likely because of a different design.
And the newer models problems are likely due to where the boards were made, and what parts venders were used in the design, along with what factory assembled it. (gotta love that outsourcing crap!)
Poor soldering, cheap relays, cutbacks, etc.... all amount to problems.
Ther is a lot of technical talk here, but how can I get Whirlpool to fix my washer with the drain problem? It is just over 1 year old, I don't have the extended warranty. Will Whirlpool provide a fix? I paid $50 for a repair person to tell me a new board is about $300 and he suggested a new machine. Is a new machine the best solution?
Your model WTW4816FW3 is referenced in the Service Bulletin pictured above. You you didn't cite the serial number, so you can check that yourself. The first four characters of the serial are relevant. Range of CC01xxxxx to CD05xxxxx (manufacture during 1st week of January 2023 through 5th week of January 2024). Advise your servicer accordingly if it is within that range in case they aren't aware of the bulletin. Or contact Whirlpool directly to arrange service. Note that replacement control boards are currently backordered/in short supply so there's a waiting period while production of them catches up.
Here's the control board at a source I often use: W11603810 Control Board for WTW4816FW3
Sounds like yet another poorly designed "New" machine.
PTZ's comment "Is a new machine the best solution?"
I'd think an "old" machine would be my choice. ;)
@PTZ if i was in your shoes i would look for a vintage direct drive whirlpool or kenmore washer like in these pics or vintage beltdrive kenmore or whirlpool what even on the market that would fit your needs that can easly be restored with help from members on the site or if you went brand new buy a speed queen tc5 1_587fb38b-4f85-478c-ba2d-6c8f30d6806f.webp00U0U_8WMSyY7UQzX_0CI0t2_1200x900.jpg597578764_2617299491981994_8845194697465361284_n.jpg
