Why Modern Cars Need Master Switches
Chetlaham
Mar 11, 2013
4,857
United States
I've been saying it for some time, but I do not believe in drive by the wire. At least not without master kill switches that drop electricity directly going to the ignition, drive motor and a gas shutoff ball valve in the fuel supply line. Along with a manual string driven backup emergency brakes.
My honest opinion is that drive by the wire malfunctions occur more than we are told about, and, it is only getting worse. Even with robust electronics there are still common mode and discrete mode software failures taking place that are impossible to simulate practically to the point in which they can be avoided in the real world.
https://www.carscoops.com/2025/08/m...e-to-stop-before-violent-crash-in-viral-clip/
Electronicification is a no-no for me.
First: electronics can be made very, very, very, very, "safe", but it is expensive and requires competence, experience and skills which are in very short supply on the market.
Second: cars are meant to be cheap, not to be safe; even the standard of automotive safety, the ISO 26262, is the most miserable standard ever seen and its main goal is to make it possible not to have competent, skilled and experienced people, because such people cost money; achieving safety is just an afterthought, a side effect.
Third: a "master switch", as you call it, is a good idea only for the cases where the so-called "idle current principle" is applied like the holy bible; this is the case of European railways, where no matter where you are, no matter what you are doing, no matter what is happening around you, if you interrupt the power supply you will never cause any damage; now think of a car suddenly braking in the middle of the highway...
I feel it better than the engine stuck cruising at 60 MPH with no brakes, no steering and no shifting of any kind like the guy in the video.
The master switches would choke fuel to the engine by closing a ball valve on the supply line via a hard physical rod and another would physically disconnect the battery and alternator electrical feeding the ignition system. So no spark plugs, no fuel pump, ect. In an all electric car this would be a link to a high interrupting DC disconnect switch that opens all sources of power to the drive motor.
The car after such kill switch activation becomes powerless. It is moving on inertia, however the engine and/or motor can no longer keep outputting power. It can no longer keep that car at steady speed or accelerate it.
Next, when safe to do so the emergency brake can be pulled steadily like on an older car, the steal wire pulls on the brake pads steadily bring the car to a stop.
Ideal? No, but better than having the engine/motor keeping the car at a high rate of speed without deceleration.
Once our previous 2020 Ford acted like it had a Master switch. We were at a restaurant in a congested dining, office and retail area. When we were leaving the dash said No key detected. Had to lay the key fob in the bottom of the console compartment and it started. You do the same if the fob battery is dead.
I will not annoy you with the details, Chetlaham, but believe me: the matter is much, much, much more complex that this, and it takes really a lot of knowledge and expertise to master it.
And is case you wonder, you have just raised the most complex and fundamental problem of "safety", and when I say "complex" I mean hellishly complex
Back in 2007, I got in the mail a recall notice about my 1986 Lincoln Mk VIII.
Apparently, a throttle control potentiometer in the engine compartment was in danger of being defective, causing instant engine speed increase and possible uncontrolled acceleration.
I planned to have the Lincoln dealer check it when I got some free time.
But two weeks later, when I started the car in my driveway, it almost "took off", revving at almost 300 RPM with my foot hard on the brakes!
When I got it to the dealer, it ran fine again, however they did the needed repair and that was the end of it.
Oh lord please give me back my 1972 Chevy Nova with it's "old school" gas pedal cable to the carb, which never gave me any problems.
Watched the video on Youtube-that e-Mustang clobbered that other car real bad once the Mustag got past the concrete divider that was guiding it. I looked at an electric converted 1990 Geo Metro about 20 yrs ago and the emergency cutoff was an Anderson connector hooked to the E-brake pedal...
You can shower me with the details on the matter. I am interested in hearing all sizes of a debate.
I can't see a simple ball valve in the fuel with a rod up to a dial being much more complex for the safety it provides in a run away car.
Here I am lost, Chetlaham: I am sure you have a quite accurate idea of how many cents such a mechanical device would cost.
But I am also confused because this is a mechanical device while, if I am not wrong, we were talking about electronics.
And I am pretty sure that the old mechanical inertial valve that shuts off the fuel in case of an accident is being replaced by something electronic and cheaper
Electronics and "drive by wire" are now found on gas vehicles as well. Electronics can call for as much acceleration as they want, good luck when the fuel line is chocked and the engine can't get gas.
That is a step in the right direction. Just change the Anderson Connector to a high current interrupting DC circuit breaker. Car can't continue running away when the DC power is cut to the drive motor.
You probably have seen the Youtube video of a Honda Pilot "running away"from a teenage driver-apparently car would not let driver switch off ignition or shift to neutral...I do not know if a Honda Pilot has vacume brake boost,but i suppose brake assist could be reduced if engine at full throttle...
Too much high-tech electronics in cars today.
Funny, we never had issues like these until all this crap was built into vehicles.
Could it be some sick corporate idea funded by covert gov to boost that "population control" agenda? 😮
"Here, stare at the dash screen so you can watch your favorite show or some porn while you're No Hands On The Wheel electronics let's you eat that cheezburger and fries."
Automotive electronics are by far the most reliable electronic devices. Any consumer will ever own
Failure rates of electronics in cars are near zero one of the main reasons for this is the federal highway traffic safety administration issue recalls when things go wrong with cars so the manufacturers have a very strong incentive to build high quality.
Of the 40 Plus mostly Chrysler vehicles that my brother and I and immediate partners have owned over the past 40+ years. I only can recall one problem with a board on one of the vehicle vehicles I had a 1990 Dodge pick up truck that had some sort of problem with the charging circuit and they had to take the main board and have it rebuilt. It’s the only time I’ve ever had a problem.
I have a 1986 Chrysler limousine with a turbo four-cylinder engine. My brother also has a 1986 Chrysler laser five speed and I also have a 1994 Plymouth voyager five speed minivan. These are are currently older vehicles. None of these have ever had a problem with the electronics
Two years ago I bought a decked out Chrysler Pacifica all-wheel-drive minivan. The car hasn’t had the first problem what a contrast when I was a kid my neighbors ordered a brand new 1970 Plymouth satellite wagon with a 383 and factory air. He asked us boys to come over and help him make a list of all the things wrong with that car we had over 39 things on a list and a half an hour This Plymouth satellite turned out to be a decent car after a lot of bugs were worked out of it at least until his daughter totaled it but today quality is so high you can just go and buy a car and have like zero problems with it
Just like Appliances we don’t have a 10th the problem with new appliances That we did back in the 70s when I think of the amount of warranty calls we did on Maytag washers and dryers and whirlpool washers and dryers, etc. in the 70s and early 80s. It was amazing how many invoices we had to hand write out making warranty claims that’s just almost totally gone away now
I believe that a PART of the problem with anything, regardless if it's a new OR older product..... is operator ignorance or improper use.
For instance: A customer brings in a stereo receiver to my repair shop.
It's got blown output transistors.
After I diagnose the issue, the customer tells me that they've hooked up multiple (too many) speakers to it and has used it as a "party machine" in the backyard.
Yes Combo 52, and that is why they have a 3 year, 36.000 mile warranty. Extended warranties covering the dash screen, and electronics are very expensive, as are the repairs. Ford has had issues with screen or software defects in brand new vehicles. Ford washes their hands of 90% of every vehicle after3 years., except for recalls or class action suits.
Keep in mind most of the electronics in a car like the engine and body computers because they control the engine operation and the emissions have a 10 year 100,000 mile warranty on them at a minimum.
These parts are extremely reliable and anything having to do with a safe operation of the vehicle Will come under the scrutiny of the highway traffic safety administration if there are problems on a regular basis
Unfortunately, there is not this type of scrutiny on major appliances or consumer electronics. They can have 90% of them fail within five years on a particular product with very little recourse unless there is a safety hazard or a fire hazard involved.
John L
The thing that gets me is steer by wire and brake by wire on the Tesla Cybertruck. While electronics can be made to be very reliable on vehicles, still want the steering wheel and brakes to be physically connected to the master cylinder and steering rack. Throttle by wire is one thing, but brake and steer by wire is a whole other thing. If there were to be a failure with brake and steer by wire, it would be extremely fatal. We will see how brake and steer by wire stands up to the test of time.
I forgot that John L. That must be the remaining 10% of the vehicle with Ford. They're good with sending emission software updates and recalls, at least to the first lessee or owner. My neighbor's wife had a 2018 Pacifica, and she liked the Explorer better, she thought. So their friend in used sales of most makes had a 2022 Explorer XLT awd with 36,000 mile on it in 2023. It was a good deal because of higher mileage. Carfax stated minor collision damage to rt. front fender, but who knows for sure? It ran and performed well then suddenly the screen began acting up, so the audio and climate controls were sporadic. They weren't aware of any software updates or recalls, etc. so they traded it to the same friend's dealership for a 2024 Pacifica loaded with leather, V6, and their payment is lower.
John L
And this is why strict electrical codes and regulations have been mandated on consumer home products.
Polarized line cords, wiring size, fusing or circuit breakers, etc.
Unfortunately, when a lot of "vintage" products were made, they would not pass current regulations.
Many a time I've had to re-wire, modify, and add proper fusing to antique radios, etc., before the customer got their stuff back.
I certainly didn't want a Liability Suit to deal with later on.
As for this "drive by wire" stuff, to hell with that!
I, and surely most people, want to be able to "feel" the road through the steering wheel.
Yes, and I feel the road more with the lane warning on if I go outside my lane. Steering wheel vibrates. I don't care for the auto correct feature. Adaptive cruise is ok, but it can be hard on the brakes.
My seat actually vibrates…
I use my cruise control all the time and I think I’m more adaptive to it, really…
It’s nice to have my car drive itself and I mostly have to worry about if and when I have to stop and know I’m better prepared because my foot is nearer and able to hit the brake better…
— Dave
Makes me laugh when that happens 😂. It’s soo funny when people claim newer vehicles are better but yet, have more problems and areas where things can fail.
If newer vehicles and modern vehicles in general were REALLY that better, anyone who works on cars and vehicles would be out of a job, period.
True words sir!
Just like over-complexity in appliances.
