Whirlpool trash
norgechef
Jan 27, 2012
308
Saint George New Brunswick
I know some of the members here might disagree with me but I think the new belt drive whirlpool washers, Cabrio washers and Duet front loaders are all complete trash, or at least the current models. I also think its very rude that whirlpool can stick good company names like Maytag on this junk they are making and make it look like a Maytag with the center dial and all that...I think its outrageous. I also know that many members here think that Herrin Maytag (Performa/Atlantis) washers were total junk but I would much rather have my Maytag Performa than one of these junk ''belt drive'' whirlpools. I know they have all the issues with balancing which is kind of annoying but I have had my Performa for 7 almost 8 years and it has had minor mechanical problems that needed fixing but it still has the original transmission and motor! I always make sure to load it right and not to stuff it to the top like most people do and it has been working like a charm for years...now id like to see one of these newer Maytag Bravos washers last that long under daily use with all those electronic controls....I was so mad when Whirlpool closed the real Maytag plants because then i knew that would be it...no more real Maytag's...just Whirlpool's in disguise. You know it wasn't too bad when they were still making direct drive machines but now there is no quality or durability put into the machines whatsoever, especially with the new energy saving standards which in my opinion aren't very good energy standards if you have to buy a new washer every 4-5 years!
me i agree that my duet washer is trash i would much rather have my inglis superb 2 direct drive washer my duet is near 10 years old but i fine the cleaning poor because of the little water inside when i am use to have clothes submerge in water if i had to buy a belt drive washer of the vintage era i would go with the inglis superb washer in harvest gold with matching dryer to have if i needed a warm rinse option
I know that Maytag's were no longer real Maytag's bu
At least the Performa machines were still half Maytag, they were made out of a rather cheap Maytag transmission and balancing system designed by Maytag which was not the best design but I still think they could outlast any Whirlpool belt drive if used properly and you have to remember Maytag still made its Dependable Care line of washers until late into 2007 when Whirlpool shut them down too...I would never disagree with someone if they said an Amana/Maytag SAV series washer was junk though...they were total pieces of crap and Maytag really failed on that design.
Sadly, the new belt drive models are proving to be very unreliable even at a year or two old. And I can't even tell you how many customers I know of that have sent them back for performance reasons. As a long time fan of direct drives (yes, I know they were not the absolute best) I had hope that Whirlpool would continue with a good top load machine.
They can't seem to leave well enough alone....
My grandmother has a 1996 Roper direct drive washer that's on the outs with a worn out neutral drain pack and a broken/unhooked spring somewhere in the drum but that thing went through so much laundry in the past that its a miracle its lasted until 2001 let alone 2013! I never really liked it because of the insanely fast agitation motion and rather slow spin but i gotta say Whirlpool really must of took pride in making that washer because its really lived up to getting the clothes washed quickly and effectively every time..
I have a Duet Clone
A Maytag 5000 Series Steam washer and dryer. Going on four years and they are not bad machines. The washer recently had to have a service call due to a pressure switch telling the controller that it was flooding when in fact it had not water in it at all. It was fixed under the extended warranty and back in business.
What I was told was that there were two different Duet models, one was made in Germany, like mine is, the other was manufactured in Mexico. The problem machines were from south of Texas.
I was, however, told the day I purchased the machine to always have it plugged into a surge protector and I would prevent many problems. I was told this as well with my new Kitchenaid dishwasher that is being delivered.
The Maytag 300 Series bought in 2007, and the last "real Maytag" design has been trouble from day one. Maytag's dependability reputation took quite a hit in the last years before it's ultimate death. Though I have stated many times I am no
whirlpool fan, at least they saved Maytag from being purchased by Haier.
I think they have all seen the "handwriting on the wall". Why would they continue to put engineering dollars into a machine that will be phased out by mandatory energy standards? I will hang onto my Tag, LAT model as long as I can. The admiral direct drive and new dryer I have are adequate, still far short of what i remember as great performers. alr
air2903, I think you have it correct, Whirlpool is just making top loaders to serve that very small market segment. Whirlpool knows they are going to be phased out so why bother to build a quality top loader. Should you want a Whirlpool DD top loader purchase a Commercial Whirlpool top loader w/o coin slot it is still old school for now.
And Here We Are Again...
I said this a few years back, Americans are going to be weened off of the top loader one way or another. Looks like the manufacturers are going to design top loaders that are SO BAD, Americans will accept mediocre FLers with open arms.
Malcolm
That is probably true...
I see where you guys are going with this...maybe they are actually purposely making them terrible so people will want front loaders but still Whirlpool has a hotline for failed drum bearings in their front loaders you know, and ''Maytag'' Maxima front loaders also have lots of drum bearing issues and those machines usually cost over $1000
Correction: Americans are being forced, not weened off Top Loaders.
Same as goes for phosphates in our detergents, the incandescent light bulb, R12 refrigerant, and so on.
None of which is free market driven.
CIT. "Same as goes for phosphates in our detergents, the incandescent light bulb, R12 refrigerant, and so on"
So you'd rather live with inferior refrigeration equipment and polluting gases?
New alternatives like R410A offer up to 100% better performance and don't contribute to ozone depletion. I hope for a large scale use of CO2 and propane/butane refrigerants, but sadly those are still in the niche market because of price and diffidence!
Classic incandescent bulbs? Good riddance!
Halogen and fluorescent are much much better and give a better luminous flux per watt!
Phosphates? Detergents have none of those since ages and we still have fantastically clean clothes! Actually EU detergents are highly rated overseas as many forum members say!
And to finish it: Whirlpool IS trash! None of their appliances I ever owned gave me any kind of satisfaction, expensive repairs and lackluster performances!
Defending all the "Naughty Stuff"
We've still got them here in Liquid laundry detergents, some powders and dishwasher powders/liquids (Esp. Finish/Fairy, both containing >30% Phosphate).
I'd hate to see our dishwasher performance if no-phosphate really does affect performance, but, we thankfully have a home water softener, so it shouldn't be an issue for us.
As for R-12 vs. Newer stuff, I can safely say that R-12 works great in the appliances that used it. I had a Kelvinator Cyclic Fridge/Freezer that got the freezer down to a nice -30ºC!!! It kept the fridge icy cold too - on the "proper" thermostat setting. R-134a is nowhere near as effective, which explains our freezer/fridges struggling. One must also bear in mind that the refrigerators these days barely have enough "oomph" to get that cold as it is.
As for R-600a, until cheap China manufacturers can make something that won't go BANG! (Esp. in Automobiles), I don't really want it. Granted, our Hisense chest freezer uses it, and has marvellously short cycles and stays pretty darn cold too.
And it's not the refrigerants fault. It is the fault of city councils and lack of law enforcement pertaining to the disposal and release of refrigerants. You still get HVAC servicemen here that (instead of) safely disposing gasses from rooftop A/C units, simply vent the stuff to the atmosphere and claim the system suffered a leak, and needs replacement - since it COSTS THEM money to dispose the gas, and they have to carry it down (Time is money!). R-12/R-22 etc are GREAT, but proper disposal is the key, as with anything.
I've seen a newer Whirlpool BD machine here in Australia. Looks heavy duty, but they are forever breaking down. They sound like steam trains (LOUD and lots of chugga-chugga), and have hopeless spin speeds (I've seen one in person. It couldn't have been spinning faster than around 400rpm). Their FL machines are okay - the one I've used is cheaply built, bad dispenser drawers (cracked/broken, even with gentle use), and it grumbles loudly during spin (used on 40/60º regularly too). Water level is up to the very bottom of the glass door though - which is pretty nice, but thats about the zenith of it!
me i am wondering the same thing just look atthis dryer that my grandmother own from 1970 to around 2010 year she had to replace her dryer it lasted her 40 years, its sad to see that they decided not to keep such good quality in term of appliances. And also if every 5 or 10 years we have to replace an appliance they need to think that it fills the local dump site when the best way and option would be to somehow recycle the appliance bu a:)eather send it to a specilise repair shop that would repair and resell the appliance as a refurbish set or b:) try to recycle the old appliance by making something else like for exemple: new appliances with recycle material from the old appliance. Thats my toughs on this.
Interesting Thread
I've thought about this myself seeing how the newer top loaders are being built to have a short life span and phase them out with FL'rs so people are forced to buy something they may not want to start using and in all probability the newer FL'rs will be built the same way of these top loaders.
So where does recycling and repairing come into place to save the environment when we'll run out of space with useless appliances 5-10 years old? My employers mother replaced a stackable unit no older than 5yrs when the repair was going to cost more than a new unit, I don't get it ??? Are we heading back to the days of the rock on the river again, lol ???
