rollermatic
just dug out my 1-18 and repaired the agitate arm problem. it ran fine for a couple days whenever i tried it out.
now the shaft that goes into the pump (with the drive belt pulley on the other end)
will turn about 1/2 inch rotation in either direction before it locks up.
tub spins freely, agitate arm moves freely when i turn roller, i assumed it was the pump locked up. i had already removed drive belt and motor is fine.
took bottom section of pump off, no obstruction in that lower impeller. i removed all screws holding pump to chassis assembly and as far as i can see there is nothing binding up the upper impeller. i could not get upper impeller loose from shaft and did want to damage pump seal so i stopped.
model no. is WIB. would like to download tech talk for the 1-18 but i see there are 3 versions listed here on the site, 1970, 1975, 1979 i believe are the choices.
besides any info on removing rest of pump to see why that shaft is locked could someone please tell me what year my 1-18 is from and which tech talk would be best for me.
thanks in advance
thanks in advance
