1938 Crane Corwith Compeer Lavatory
After a thorough cleaning, still looking perturbed.
<script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
How in the world can you clean this? The mesh is corroded and while intact, it can easily break.
This is concerning. While the crack is not visible in the back, I decided to use an angle iron in the back as additional support.
Try Whink Rust Remover on the faucet mesh Louie. It should help you get most or all of the rust off. But if the metal is rusted thorough it may also break off too.
I think your idea of providing extra support by bracing the back of the sink where its cracked is well advised. I’m impressed with your attention to detail and the progress you’re making. Keep up the good work, it will be worth it in the end.
Eddie
https://www.walmart.com/ip/Whink-Rust-Stain-Remover-16-oz/15716648
This O ring has proven to be difficult to find. The owner of DEA was very helpful. He told me the valves on my Crane are most likely from another brand, not original Crane, hence the issue finding the correct ring. Nevertheless he recommended Rectorseal pipe thread sealant and it would work just fine.
