bradross
Hello...for all the wringer fans, I've acquired yet another! I was in Washington state visiting a friend, and just happened to see this in front of an antique store as we drove by. This Kenmore is, I believe, from the late 1940s. If anybody can verify that, I would appreciate it. The model # 110 73230.
It has a pump mechanism similar to that of a Maytag. A lever on the side engages the pump by shifting the whole mechanism, including that driving pulley, so that it makes contact with the flywheel/driveshaft of the motor. The flywheel has a rubber coating so the pump drive makes good contact.
Everything seems to be working fine, but of course, I'll be taking it apart to have a look. The motor runs very smoothly and EXTREMELY quietly! Only thing that needs replacing immediately is the drain hose, as it's brittle with age. The rolls of the wringer are pretty hardened, but still functional.
One thing I noticed from the first trial washing...as compared with the Maytag, this Kenmore does not have a sediment trap. At the end of the washing after draining the washtub, there is all the sediment just sitting on the bottom of the tub, since it's flat. Definitely not as well-engineered as the Maytag, but it still has great roll-over action - the three vane agitator turns about 180 degrees.
