1950 kenmore help
marty
May 30, 2011
188
Central Point, Oregon
The hose that goes from the tub to the pump is broken. I called Larry at Modern Appliance and he said someone just purchased all that he had. Can someone point me in the direction for a new hose, or a good used one. If not maybe someone needs parts off of this machine?
Regards
Marty
541-621-9166
can we get a pic of the one you need......
is it the one that goes directly from the tub to the pump......no pump guard?.....best solution I seen from John was to install the rubber fitting in the base, with the pump guard and then the four inch hose to the pump......
or is it with a pump guard, and you need that 4 inch piece to connect to the pump....this one is simple.....Lowes sells reinforced hose, clear, 1 1/4 inch...buy a foot and cut to fit.....
almost anything can be improvised!
