Here's the transmission, dated May 12, 1950. There's also a water level float switch that says March 20, 1950. With my eyes and a flashlight, 1950 is clear as a bell. The pump is entirely siezed, as was the suds pump. I have an 80's 2 port drain pump I will install, all it requires is removing the linkage from the neutral drain cam, and replacing the cam with a modern one. The suds pump---I oiled it down a long wick and 2 oilholes on the shaft, the next day it turned, so it will go back on the machine.
